Starter Removal
Old Apr 17, 2007 | 01:39 PM
howey's Avatar
Starter Removal
Hi:
I want to drain the coolant on my 99 Z28. Getting the right rear drain plug out may involve removing the starter. The manual says that one must drop the Y pipe to do this.
Looking at it I can't see why this is required; I must be missing something.
Has anyone had bad experiences in draining the coolant; I like to drain the block every few years. Chevy doesn't draiin the coolant; they run it thru some sort of reprocessor. That worries me.
Old Apr 18, 2007 | 07:36 AM
AL SS590 M6's Avatar
Moderator
I see no reason why you couldn't just unhook the low oil sensor and pull the 2 starter bolts to swing it out of the way for access to the coolant drain plug.
Make sure that you drain the other side too. The plug for that side is behind the alternator.
Old Apr 18, 2007 | 07:39 PM
LiENUS's Avatar
Originally Posted by howey
Hi:
I don't know bout the LS1 but the LT1 the y-pipe prevents the starter from falling all the way down. AL SS590 is right, you should be able to unbolt it then just swing it out of the way. Just be sure to unhook the battery before unbolting the starter (shorting out the starter sucks)
Old Apr 19, 2007 | 11:49 AM
GreenDemon's Avatar
I had to do that last summer. Just unbolt the starter and swing it out of the way and you'll be able to access the bolt. Don't forget to cover the cable post with a rag or something to prevent sparking (if you're not disconnecting the battery).
Old Apr 19, 2007 | 06:12 PM
Capn Pete's Avatar
No need to drop the Y-pipe .
DSMKilla
Jun 11, 2015 05:02 PM
Jun 6, 2015 08:27 AM
lt1matt
Mar 21, 2015 07:35 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
thenewkid
Nov 18, 2014 12:57 PM
