stalling when tipping into the gas??
Old Jul 19, 2005 | 04:37 PM
L8ER's Avatar
Ok guys here is my problem. I have had my pcm retuned ,then I put headers and an off road y-pipe on so I had to have the airpump turned off as well as the EGR. So I sent it in again to have those things done.After the second tune I can drive my car for about 30 min park it and wait 20 min. When I start going it runs fine .I will go about two blocks and it will start to fall on it's face. it's like it is flooding out or something. It only does this about 8 to 10 sec then it pulls out of it. It will be fine after that until I shut it off again then the same thing will happen. It seems funny that it will only do it one time and after that it is fine. Has anyone had this happen and what was the cause??
Old Jul 20, 2005 | 12:35 PM
PAGregSS's Avatar
Re: stalling when tipping into the gas??
I had similar symptoms and it turned out that my positive battery cable that ran to the starter had come up against the longtubes and melted and the wire was arching off of the headers. It made the car run like total crap.
Old Jul 24, 2005 | 01:37 PM
L8ER's Avatar
Thanks for the info man, I checked out all the wires and nothing is touching the headers.If you think of anything else let me know. Thanks.
Old Jul 31, 2005 | 12:17 PM
L8ER's Avatar
Ok I have some more info that may help. I have noticed that the first time I start the car after setting all night it doesn't do it. It is when it's hot and sets for a little while.After looking closer to the exhaust I noticed that it runs fairly close to the fuel lines under the car. Could this cause this problem??
Old Aug 3, 2005 | 08:08 PM
L8ER's Avatar
Ok I have some new info: After installing the LT"S and Y-pipe my car get very hot under the hood. I can feel the fuel rail and it's very hot. Brake linds are hot, has anyone ever had this with headers? Could it be getting to hot under the hood and causing some kind of vapor lock? this is just goofy.. If I let the car sit for just a little bit it doesn't do it. But if I let it sit for 15 to 20 min, it will bog down for a little bit. Like it has to run the fuel for a while then it is ok.
Old Aug 4, 2005 | 05:37 AM
QuickSilver02's Avatar
Is your idle set too low? That fixed my surging problem.
Old Aug 4, 2005 | 11:59 PM
L8ER's Avatar
I don't think so , it is at 585 to 600. and it will only do this crazy thing one time. Then after it cleans out it runs great.
Old Aug 5, 2005 | 06:43 AM
I got quite a few mods done so my idle is set at 900. Before I had it tuned, anything below 700 would make it die.
Old Aug 7, 2005 | 01:43 PM
L8ER's Avatar
ttt
Old Aug 7, 2005 | 05:18 PM
L8ER's Avatar
It doesn't seem to be the idle. It is when i step on the gas just a little bit then it boggs down. Kinda weird but getting pissy about it. I have tried to catch it on auto tap software. But have not had luck with that yet..
May 15, 2015 10:43 AM
cobrakilling101
14
Mar 17, 2015 10:42 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
simple
Aug 11, 2002 11:56 AM
