SSRA questions
Old Jun 17, 2004 | 01:29 AM
TA_LS1's Avatar
SSRA questions
first, how much does it cost generally, and where can i get it?
How would it work on my TA concerning rain? i know these cars are pretty low to the ground, so is rain a problem? also, would there be a problem with bottoming out on somewhat steep driveways?
is it worth it for the gains? am i better off with a cold air system like SLPs?
Old Jun 17, 2004 | 02:33 AM
99blackSS's Avatar
Usually costs around $100, several of the sponsors on this site offer it. Most people say rain isn't a problem with it. It wouldn't affect your ground clearance at all. I would go with a CAI instead. Ram air on cars is very debatable, the majority on this site swear by the SSRA though.
Old Jun 17, 2004 | 03:16 AM
AL SS590 M6's Avatar
Moderator
Re: SSRA questions
Go here http://www.speedspecialty.com/store/index.php?cat_id=2
For the rain you can make a block off. Some use high density foam stuffed into the scoop. I made a aluminum plate that blocks it off at the air box.
Care will be needed with anything that is closer to the ground.
The gains are proven. If I block mine off I slow down .1 and 1mph. Open it up and I get the time back.
Old Jun 17, 2004 | 07:23 AM
teke184's Avatar
where the heck are you getting the SSRA for $100
try $200 is about the cheapest you 'll see
i have a link in my sig if need be
rain hasn't been a problem (south florida) and as for clearance. it easily clears parking blocks and most curbs. don't have steep driveways so don't know about that
Old Jun 17, 2004 | 07:26 AM
falchulk's Avatar
Heh heh, my car without the ram air has a problem with steep driveways! I have scrapped at least 3 times in the 2 or 3 months I have owned the car. But then again, I live in a mountainous area with LOTS of steep driveways.
Old Jun 17, 2004 | 10:36 AM
Buffdaddy's Avatar
SSRA I think would be great for the induction. However if you drive the car in very wet conditions that could be a problem. With all the rain here in Indiana some of the roads have flooded and their is no other way to go and I think the water would just get sucked up and cause some damage. But I could be wrong and if you have a block off plate that should be fine.
Old Jun 17, 2004 | 02:14 PM
99blackSS's Avatar
I am not getting the SSRA. Nor any other type of "ram air". Your right though, SSRA is more then I thought, I was looking at other ram air kits.
Old Jun 17, 2004 | 10:14 PM
gav'spurplez's Avatar
SSRA rocks
I have driven in really heavy downpours on the highway and have had no problems. ground clearance is not bad either. only thing you need to look out for is standing water ( Flood )
You can always remove the lower scoop if you are concerned
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
