SS vs SLP
Old May 21, 2003 | 10:22 PM
hansa320's Avatar
SS vs SLP
As a new honored member to this forum, I beg in advance for your understanding to my ignorance.
I am in the process of buying a Z28 or SS. Live in Louisville, KY.
My question is this:
There is the Z28, then there is the SS. Is there different models of the SS?
What does SLP mean/include?
Modell year I am looking for is 98-02. Should be a 6 speed. Any suggestions on what else, and what to look for when that shining beauty has been located?
Sincerely,
Stein
Old May 21, 2003 | 10:40 PM
demonspeed's Avatar
Welcome to the board! I'll make this simple for you... do a search hehehe...
Honestly though, the main thing is you have the V6, Z28, then SS which is a SLP thing.
Old May 21, 2003 | 10:45 PM
petegz28's Avatar
An SS is a Z28 that is sent to SLP to have the tires, suspension and etc. upgraded. You will notice SLP has a lot of great deals on "take off" parts. These are the parts they take off the Z28.
Old May 22, 2003 | 02:49 AM
danno02SS's Avatar
Welcome hansa320,
As demonspeed mentioned your better off searching the archives for detailed threads on to the differences between the Z28 and SS. I'll take a quick stab at the major points (stats for 2002).
Z28 5.7L LS1 V-8, 310HP@5200RPM 340ft-lbs@4000RPM
STD Features:4-speed Automatic Trans.(2.73 std., 3.23 optional), or 6-speed Manual (3.42 std., Hurst short-throw optional), 16"x8" Aluminum wheels w/ Eagle RS-As, Zexel-Torsen LSD, Performance Ride and Handling Package
SS(Z28) 5.7L LS1 V-8, 325HP@5200RPM 350ft-lbs@4000RPM
STD Features:Forced air-induction hood and high rear spoiler, 4-speed Automatic Trans.(3.23 std.), or 6-speed Manual (3.42 std., Hurst short-throw optional), 17"x9" Aluminum wheels w/ Eagle F1s, Zexel-Torsen LSD, High Performance Ride and Handling Package (bigger front sway-bar), Low-restriction exhaust with dual outlets
SLP options for SS (335HP or 345HP)
Bilstein or 1LE Suspension, Auburn LSD, BFG G-Force KDs, Chrome ZR1 or 10-spoke wheels, Dual-Dual Performance exhaust or Center Mounted Performance exhaust (+10HP), Blackwing LID (+10HP)
I think i covered most of the stuff. The '01-'02 cars are rated the same (SLP LID option not available for '01). '98-'00 cars are rated slightly lower. The '98-'00 cars came with a bigger cam but did not come with the LS6 intake manifold. The exhaust manifolds for the '01-'02 cars were also redesigned. Hope the info helps.
Old May 22, 2003 | 07:28 AM
SS HOTTIE
Guest
Posts: n/a
SLP= Street Legal Performance, and yes they are responsible for the SS's upgraded performance and appearance package.
Old May 22, 2003 | 11:42 PM
hansa320's Avatar
Thumbs up
Thank you all, for your input.
Still looking. I need to replace my commuter car for the fall season.
The car will be used from Louisville, KY to Detroit, MI. 3 times per month. All of 340 Miles.
Thanks again.
Stein
Old May 25, 2003 | 06:38 PM
demonspeed's Avatar
Why don't you keep the SS for your play vehicle and get something like a Cavalier for your commute? Just wondering...
Old May 29, 2003 | 09:06 AM
hansa320's Avatar
Spending 4.5 hrs in the car each time, Just after a long day sitting
at work? It needs to be very comfortable. I am also considering tradin up on my 560 SEC. It has now 235K miles, and is due for replacement.
Comfort is actually more important than tire smoking power.
A Cavalier??? I am 6'4", 230 lbs, would almost be funny to see....
Thanks for the coment!!
Stein
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
