speed limiter
Old Aug 27, 2003 | 03:59 PM
cdmelcher's Avatar
speed limiter
has anybody ACTUALLY posted in here they have a speed limiter at 108? I mean really saw it cut out at 108mph? I have heard of the RARE occasion that a Z28 had this limiter BUT nobody to my knowledge has flat out said they witnessed this limiter.
Old Aug 27, 2003 | 04:05 PM
ls1_bc's Avatar
Lots of people have posted re speed limiter.In fact all Camaros and Firebirds that came from the factory without Z rated tires have the speed limiter.I think mine was set to around 115-120mph.
Old Aug 27, 2003 | 04:06 PM
99blackSS's Avatar
Theres no way its 108mph, you must mean 118mph. My V6 Camaro has a limiter at 118mph and I have seen it. If the car came with Z rated tires the speed limiter is set at 163mph.
Old Aug 27, 2003 | 07:45 PM
Mister Will's Avatar
My '96 Z28 would cut out at 114 mph. Before the LS1s that was understood to be the set top speed imposed by the speed limiter.
I don't know why they would change it? Perhaps the variation we are seeing is due to an inaccuracy in the OEM speedometer.
P.S. I made sure to have factory Z rated tires when I purchased my '98 LS1
Old Aug 30, 2003 | 11:30 PM
Akshay's Avatar
Replace you fuel filter and try again. Or your tach may have reached redline.
Akshay
Old Aug 31, 2003 | 04:47 AM
mr_muff's Avatar
well i know you can wrap the speedo and not hit the speed limiter in my ss.
Old Aug 31, 2003 | 10:41 AM
psychocabbage's Avatar
not 163.. fuel shutoff will happen when you hit 163.. probably.. but the limiter is set at 155. at least thats from what I have seen.. hehehe
Its possible the car will hit and maintain 163 in stock trim with no limiter.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grabbem88
Feb 10, 2015 06:20 PM
94_formula
Jul 20, 2002 11:19 PM
