Sparking valve cover
Arching valve cover
This goes along with what I posted earlier about the ticking coil pack. Well it wasn't the coil. I replaced it and still does the same thing. What I did find out though is that you can visually see spark jumping from the valve cover to the head in the front which is causing the tick, or more like a crackle.. It is also arching, in the rear of the passenger side valve cover. What the hell is it? For the life of me I can not figure it out. Could this be caused from a bad ground or something?
EDIT: Upon further evaluation, it is arching from the head to the accessory bracket.
Found out that the rear most spark plug wire had fallen off and was causing the arcing, after some contortion with my big hands I was able to get it back on. Thing runs like a raped ape again!
