spark plugs
Old Jul 21, 2005 | 08:29 PM
  #16
Greed4Speed's Avatar
Re: spark plugs
Copper
Old Jul 22, 2005 | 09:39 AM
  #17
shouldaboughtthez's Avatar
Re: spark plugs
Originally Posted by SpeedDemon02SS
sorry cant remember the name..brain fart...but...
do the wires come wht the 'hands' that hold them in place over the valve covers? also, are they cut to the right size with boots, or do i have to cut them myself?
Mine were cut to the right lenght and already put together.
Why are you ordering plugs from Summit? Why not get them from the parts store down the street?
Old Jul 22, 2005 | 09:59 AM
  #18
SpeedDemon02SS's Avatar
Re: spark plugs
at first it was just easier cause i was ordering the wires from them. but the wires arnt in stock, so im getting them at the local store, and ordering the wires.
Old Jul 22, 2005 | 08:47 PM
  #19
angel71rs's Avatar
Re: spark plugs
more like...if i have bad plugs and wires now; how much power am i losing from bad plugs and wires?
I felt a clear difference when I replaced the factory plugs at 50k. You can't feel a 10 hp boost, so figure at least 20 hp. The originals were in really bad shape, some were missing the little puck on the ground electrode, huge gaps. I used regular Bosch platinums, cheap at Autozone. I ohmed the original plug wires and all were ~ 300 ohms, so I reused them. I have read that some guys tear up the wires removing them, but I was careful and got them off no problems.
Old Jul 23, 2005 | 07:46 AM
  #20
danziger's Avatar
Re: spark plugs
NGK TR55s are a good choice for N/A and gap them around 55-58ish. I have the NGK TR6s gapped at 38 and they are also a great plug...especially for nitrous.
Old Jul 24, 2005 | 07:25 AM
  #21
KY98LS1's Avatar
Re: spark plugs
Spark plugs are PITA to change on LS1. AC Delco has an iridium plug which should last longer than $2 spark plug.
Old Jul 24, 2005 | 11:33 AM
  #22
Keliente@pcmforless's Avatar
Re: spark plugs
You are not going to get any hp gain with new plugs or wires. Sure we've all seen people get up on the dyno with new fancy $10 each plugs and show a few more hp - but most folks forget that it's easy to trick a car into gaining a couple points by letting it cool down fully, etc...
I get the $1.88 NGK TR55 plugs and they work just fine gapped at .050. I originally gapped them around .058 and the car broke up really bad over 5500rpm. I would never replace the wires unless one of them was damaged, it is a waste of money.
Old Jul 24, 2005 | 11:34 AM
  #23
Re: spark plugs
And since you said you've never done the plugs before, do yourself a favor and get #8 from underneath the car.
Old Dec 14, 2005 | 01:22 AM
  #24
GoFast908Z's Avatar
Member
Re: spark plugs
so which is it?...... 0.50 or 0.58 ??
Old Dec 14, 2005 | 08:09 AM
  #25
Re: spark plugs
.55
Old Dec 14, 2005 | 10:25 PM
  #26
hot white z's Avatar
Re: spark plugs
I agree with Greed4Speed, you don't need anything special, and avoid platinum+4's, +2's, splitfires, rapidfires, and any other gimmick out there like the plague. I always replace my plugs with AC Delco's. Your engine will love you if you put exactly what came in it back in, in your case AC Delco platinums. You can get any 8mm or 8.8mm low-resistance wire you like and you'll be fine. I've used the Accel and MSD wires and they both work like champs. An MSD box will help a lot if you invest in one.
Old Dec 15, 2005 | 01:49 PM
  #27
Re: spark plugs
Not with an LS1.
Old Dec 15, 2005 | 02:26 PM
  #28
Re: spark plugs
Originally Posted by Greed4Speed
Not with an LS1.
Dont you only need an MSD box if you have N20, forced induction, or some serious internal mods?
Old Dec 15, 2005 | 06:51 PM
  #29
Re: spark plugs
Not on an LS1.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
