spark plugs
Old Jun 22, 2004 | 09:31 AM
mergleh00SS's Avatar
spark plugs
can someone please tell me the best spark plugs i can get for my 00 SS thanks!
Old Jun 22, 2004 | 10:18 AM
MikeyG's Avatar
NGK TR-55's.
Old Jun 22, 2004 | 08:03 PM
Greed4Speed's Avatar
One that ignites the fuel.
A plug is a plug is a plug. NGK is just the trendy brand at the moment.
Old Jun 22, 2004 | 11:56 PM
zo6vette's Avatar
how about the bosch platinum 4 plugs? are those good plugs to use?
Old Jun 23, 2004 | 10:19 AM
MikeyG's Avatar
Platinum plugs will last the longest, but it does not provide as strong of a spark as copper. Also, the +4s are just a gimmick, the spark winds up just going to the same electrode every time. If you don't get NGKs, AC Delcos would be my next choice.
Old Jun 23, 2004 | 06:53 PM
I concur, except that irridium lasts longer than plats, but there again..it doesn't conduct as well. Its a trade off, but since our ignition systems are designed w/platinum plugs in mind I'll personally stick with them. That and I don't care to change plugs like I'd need to with copper.
All those multi electrode plugs are gimicks to get you to pay more. If they make a difference, you have problems else where or its the same diff a regular electrode plug would have made.
Old Jun 24, 2004 | 04:40 PM
Y2K2Sierra's Avatar
The first time is hard, but after you figure out that back passenger cyclinder it will be easier the next time. I can change my plugs in less than 30 min.
I would recommend the NGK Tr-55's. They are a copper plug, so you will have to change them more often (every 20-25K miles), but they work great and are cheap.
Chris
Old Jun 26, 2004 | 04:45 PM
mw02's Avatar
I'd also recommend tr55's.
Stay away from Iridium unless you like paying more $ for no reason. If so, PM me and Ill give you my address.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
