spark knock
Old May 22, 2008 | 06:45 AM
  #16
AL SS590 M6's Avatar
Moderator
Originally Posted by smslyguy
i have never tunned the car or had it tuned, i bought the car with 19,000 miles on it and it currently has 27,000. I dont know if the previous owner has had it tuned or not, but it has spark knocked sinse ive owned the vehicle. My buddy has a scanner which we hooked it up on and it was misfiring from cylinder to cylinder only under load, while it was spark knocking. It doesnt do this when the vehicle is cold though. Only when its up to operating temperature. I've been looking into tuners but im pretty confused to all the in depth reading you have to understand for them.
You really need to try the simple things first. You could just have carbon on the pistons making hot spots causing the spark knock which makes the computer pull timing reducing power.
Seafoam thru the brake booster hose.
Old May 22, 2008 | 07:53 AM
  #17
smslyguy's Avatar
spark knock
Originally Posted by mrmint69
Unmeasured air entering the engine. Maybe something is loose or disconnected.
nothing is loose or disconected. WOuld this possible be needing a tune from the bolt on listed above now? But like i was saying earier the spark knock was there before any of these were installed
Old May 22, 2008 | 08:08 AM
  #18
Marc 85Z28's Avatar
The reduction in power is a result of the spark knock you hear, not the other way around. The most likely cause is carbon buildup on the pistons causing hot spots. Those hot spots are creating combustion events at the wrong time creating the detonation or pinging noise you hear. The PCM hears this same noise through the knock sensors, and is most likely pulling a ton of timing to eliminate the condition. The detonation may be so bad that pulling timing isn't enough, and even with the several degree of retard the detonation still occurs. Less timing means less power. The misfire detection may be phantom. Combustion events that don't occur when they should create a power imbalance - power imbalance is how the PCM detects misfires. A misfire means a combustion event does not take place when the PCM thinks it should. It cannot tell the difference between a combustion event not taking place and one taking place at the wrong time in the engine cycle.
The point is, Seafoam it already and see how that works for you! Do the necessary (and inexpensive) maintenance first, then start looking towards other issues.
Old Jun 11, 2008 | 09:27 PM
  #19
smslyguy's Avatar
i have used seafoam and i still have spark knock any other suggestions? is this typical for these cars to have spark knock from the factory?
Formula Steve
Sep 19, 2023 08:31 AM
Pwilson59
Sep 3, 2015 08:47 PM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
