SLP LT headers and SES light???
I just install SLP LT headers with their high flow cats and y-pipe also, everything by them. I put on about 50miles or so and the SES light came on??? It runs find, I do smell alot of exhaust fumes, a friend of mine said it could run to rich and I could install a Mass translator to my already Mass air meter by SLP to lean it out some? Could that have anything to do with it? Or is it the rear O2 sensor, and I need a simalator for it? Any help would be great.
It's probably the 02 sensors. You can check with Auto Zone first, they can put your car on a computer and check it for free. If that's the problem, put o2 simulators on, and the problem will be fixed!
Re: code
Originally posted by hrtbeat2
I went to Autozone and the codes said heater bank O2 sensor 1 and second code said heater bank O2 sensor bank 2. The code started with a P?
Re: code
Btw, I think all the codes start with a P.
Re: Re: code
Originally posted by Camaro ChriSS
Sounds like the front sensor on each side.
u can get more info at autotap.com
Like I said infrequent switching. O2 simms will not help you. The only thing that works is to reset the computer every time the light comes on with autotap or pulling the connector off the battery and resetting the PCM.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
