SLP fan switch
I just bought an SLP fan switch, and I wanted to know how can I attach LEDs (on off) to it? Im no electrician so anybody who has some easy to follow steps on how its done, I would appreciate it. Thanks
basically for 2000+ you take pin 42 ( blue )
connector ( wire from it) and splice into into
it and anytime that wire is connected to ground
the low speed fans will come on. Need high
speed fans.. just turn your AC on MAX.
here is the pinouts..
http://www.ls1info.com/article.php?sid=80
I rarely use the fan switch, unless at the track
because the AC on trick works better..
carguyshu
Jan 22, 2017 11:19 AM
Rich_z28
Aug 29, 2002 10:44 PM
