SLP cold air induction
Old Mar 24, 2004 | 06:00 PM
  #16
02pewterss's Avatar
Thanks everyone for the imput. I think I will put everything in except the MAF at first, try it out, then put the SLP one in and try it. According to SLP description of it, it helps a lot. We'll see though. Thanks again!
Old Mar 24, 2004 | 06:47 PM
  #17
AronZ28's Avatar
Of course SLP will say it helps a lot. They are trying to sell product. If they say it gave a 10hp increase over the stock one, they might have tested it on a highly modified motor. I doubt they got their increase number from a near stock motor.
Old Mar 24, 2004 | 06:52 PM
  #18
02pewterss's Avatar
I wish I had known all this BEFORE I shelled out the 160 for it.
Old Mar 24, 2004 | 07:12 PM
  #19
steve-d's Avatar
Originally posted by WazzuZ28
I did this install last weekend, and it took me about 2.5 hours, and that was going very slow making sure I didn't screw anything up. Get some tin snips and a SHARP hack-saw...they make trimming the filter base and deflector plate a breeze.
I'd suggest a Dremmel to do the cutting. The snips may crack the plastic. I learned the hard way. With the new piece the Dremmel made easy and clean work of it.
Steve
Old Mar 24, 2004 | 07:55 PM
  #20
1stls1's Avatar
I'm sorry, you guys have me a little worried. What is this talk about cutting and sniping w/ a new lid!? I am just about to order this and I thought it is a drop in part?
Old Mar 24, 2004 | 08:00 PM
  #21
02pewterss's Avatar
The cutting and snipping is for the cold air induction not the lid. The lid will take 5 minutes to install. Don't worry.
Old Mar 24, 2004 | 10:58 PM
  #22
Drew98's Avatar
Bauer posted a dyno on ls1tech where they dyno'd a ported TB on a bone stock car and picked up like 8rwhp. Look at a ported one then look at the stock one... its ridiculous.
Old Mar 25, 2004 | 07:18 AM
  #23
jasonss's Avatar
then why does a stock z06 vette use a 85 mm maf, instead of the stock ones on c5 and f-body, they just have 50 more horsepower, i put slp maf on my 00 ls1 6-speed, and with just that i ran a 12.98 on street tires
Old Mar 25, 2004 | 05:51 PM
  #24
twozs's Avatar
i cut mine with a porter cable tiger saw with a metal cutting blade, put those girly tools away
Old Mar 25, 2004 | 06:13 PM
  #25
02pewterss's Avatar
Instead of using a sharp awl and hammer to make the hole to mount it can I use a drill?
Old Mar 25, 2004 | 07:29 PM
  #26
ULTIMTEORANGESS's Avatar
an ls6 is a little different.it probably is tuned to run with a bigger MAF due to better flowing stock heads.
as was mentioned earlier some people have good results using this and others dont.
Old Mar 26, 2004 | 10:21 AM
  #27
02pewterss's Avatar
Can I do this or not? Thanks
Old Mar 26, 2004 | 11:39 AM
  #28
steve-d's Avatar
Yes, exactly how I did it. Worked well and very quick
Steve
Old Mar 26, 2004 | 12:07 PM
  #29
02pewterss's Avatar
Thank you Steve
Old Mar 26, 2004 | 12:09 PM
  #30
Drew98's Avatar
exactly!
