Slight lope in idle on stock cammed car
Old 02-01-2006, 08:43 PM
z28chrizz's Avatar
Hey.. I have developed a slight lope at idle in my M6 2000 Z. I think I did it when I hacked off the extra junk from the EGR into the intake. Anyone know of a way to check to see if that is leaking with typical tools? Tricks to see if its leaking there?
Any other common sources of lope? My car is a low mile (39k) car thats been garaged its whole life and is virtually stock except for free mods, a lid and cutout.
z28chrizz is offline
Old 02-02-2006, 10:27 AM
Greed4Speed's Avatar
Re: Slight lope in idle on stock cammed car
Spray some starting fluid in the area. If idle increases thats you culprit.
You can use H2O also. If the idle smoothes out that would be your indicator.
Greed4Speed is offline
Old 02-03-2006, 10:04 AM
Bayer-Z28's Avatar
Starting fluid?? Isn't that a bit risky?? Ignition...Hot manifolds and everything...I wouldn't mess w/ either.....JMO
I've heard brakeclean, but that and black plastic engine parts... I've stained my PS resevoir w/ aluminum cleaner. Cant get it off now...
Bayer-Z28 is offline
Old 02-03-2006, 03:50 PM
Thats why you don't do that on a hot engine....
Old 02-03-2006, 04:27 PM
z28chrizz's Avatar
Aren't they both really flammable and evaoprate quickly? I will try that, but will be careful in doing so...
Old 02-03-2006, 07:22 PM
Or you could try the water in a sqirt bottle.
Old 02-04-2006, 08:41 AM
Moderator
AL SS590 M6's Avatar
Many many folks have done the EGR tube mod and had the O-ring fall out of place when installing, causing a vacuum leak. It's about a 2 second job to loosen the bolt and check it.
AL SS590 M6 is offline
Noenav
03-01-2019 07:38 AM
USAirman93
11-24-2014 03:37 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Queens94z28
11-20-2014 06:03 PM
Dave19yz28
01-26-2003 01:45 PM
Quick Reply: Slight lope in idle on stock cammed car
