siren sound at rear??????
Old Feb 19, 2003 | 10:47 PM
  #16
2000TA's Avatar
Originally posted by red91tsiawd
i'll try y hardest for a new rear
thanks for the help,
mike
ok Look I had to take mine bacK to the Dealer Like 3-4 times first they tried changing the Fluied than other things but I pushed and Pushed Had the manager ride with me in the car each time. I was even fixing to Write Pontiac. they got fed up with is and said they were judt gonna replace the whole Rear end. whan i got it back it was fixed than I asked if they found the problem. they said that for some reason the gears had alot of Wear so inturn had some play and that was the noise I was hearing.... oh buy the way they even tried to tell me it was the posi one time. and it was built like that.... Yeah Right
Old Feb 19, 2003 | 10:51 PM
  #17
chpmnsws6's Avatar
^the reason i hate dealers so much. so i should just keep riding them till i get a new rearend?
thanks,
mike
Old Feb 20, 2003 | 06:49 AM
  #18
2000TA's Avatar
thanks,
mike
Till the prob. is fixed... don't let it slide . that is why youe car is covered
Old Feb 20, 2003 | 11:09 AM
  #19
chpmnsws6's Avatar
wut about the clanking at the rear end??? it does that when i switch gears.
still love the car though
mike
Old Feb 20, 2003 | 11:49 AM
  #20
dmnall's Avatar
Well like some people are saying, keep hounding the dealership untill they fix the whining noise. The noise that you are hearing when shifting is normal if it is a M6..
Well I drive my dad's 2000 Silverado w/ 4.3L and M5 once in a while and when shifting it sounds like a bad transmission mount, I have checked the mount personally and even the driveline, so it is normal.. It could be just the freeplay in either Tranny or Rear End... That noise is normal but the whining noise sounds like either the Ring and Pinion Backlash is not set correctly or the Pinion Depth is not set up correctly.. Either way have the dealer check the Backlash and pinion depth...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
