Should i get hypertech?
i thought about getting it but im not sure if its woth the money? I would prob only get a 10hp increase. Do u think its worth it?
2002 navy blues SS slp air box and dual/dual exhaust 345 hp (a4)12 disk cd changer
SLP SS grille 10spoke chrome rims
T-Tops
best 1/4 mile 13.08(gtech)
T-Tops
IMO, they're not worth it unless you can find a used one really cheap so if you don't pick up much power then you're only out 100 bucks or so. Actually, the only reason I'd probably get one is if I did a gear swap or to get rid of the governor(speed limiter), if I had one.
Aaron
Black ’96 Z28 *sold*
SSM '02 Z28
Pro 5.0, FRA, MTI lid
¼- 13.21@108.2
Aaron
SSM '02 Z28
¼- 13.21@108.2
<font face="Verdana, Arial" size="2">Originally posted by Sinister SS:
Bird Killer,
You live in OK! Go see Ed! Get it done right on the dyno.
</font>
Bird Killer,
</font>
T-Tops
If you had a M6, then I would say skip it. However, with the A4, it really does change the way the care drives.
I dynoed stock and then with nothing but programming and picked up 14 RWHP on my 2001 Z28
<font face="Verdana, Arial" size="2">Originally posted by Z_28_0117:
And what's with being able to buy a used one, Hypertech says once you plug one in it "marries" itself to the car?</font>
Aaron
SSM '02 Z28
¼- 13.21@108.2
<font face="Verdana, Arial" size="2">Originally posted by jthomas:
so what, exactly, were the parameters that you changed to get the 14 rwhp increase?</font>
6400 Rev Limiter
Still had stock thermostat
Tranny was set as follows:
Shift firmness -- 50 %
Shift points:
1-2 +2
2-3 +2
3-4 +3
When I owned my '96 Z28 M6, I re-programmed it with a Hypertech - it was worth it for me just to get the engine temperature down. That's the only thing I don't like about the camaros I've owned - they run too hot! I'm going to get one (and powerstat) for my '99 Z28 A4.
<font face="Verdana, Arial" size="2">Originally posted by U2Slow:
6400 rpms?
is that litle to much? do you hit the rev. limiter?
I got mine at 6200, i was worried about moving it more up...
should I move it up a bit?</font>
6400 rpms?
