Should I buy this car???
Old Jan 3, 2004 | 01:51 AM
xlr857's Avatar
I found 2002 Z-28 with 13,000 miles fully loaded, AT. Price is $17,000. Here is my dilemma it only has the GU2 code and I was kind of looking for the GU5 performance axle. Is this option a huge deal. This car is real clean. What is the difference in 1/4 mile times between the two. Should I hold out, or try to make a deal on this car. Will a Z-28 with the GU2 still run in the 13's stock. Any help greatly appreciated I am desperatly trying to get into a Z-28 but I dont want to let my eagerness overwhelm me into a stupid decision.
Old Jan 3, 2004 | 02:07 AM
Gold Z's Avatar
With either gear the car will still run 13s all day. The 3.23 geared car will be faster but it's not a big deal. You can buy complete 3.23 geared used rearends for $200 to $400 and just swap them out. The steel driveshaft isn't a bad thing until you start turning very high rpms. Your speed limiter will be set way low but just locate a shop that does LS1 Edit tuning and they can set your speed limiter where ever you want it and reset the speedometer to work with the 3.23 gears if you should change them. My own opinion is that if the gearing is the only problem then I would go ahead and buy the car. It sounds like a good buy to me.
Old Jan 3, 2004 | 04:18 AM
99blackSS's Avatar
A GU2 will still run in the 13s.
In a area like Phoenix I am sure you could find the car you want.
Old Jan 3, 2004 | 06:29 AM
Ron78Z&01SS's Avatar
When I had my 95 Z A buddy of mine had one too. The only difference was I had leather, tops, and 2.73's ad he had 3.23's (they were even both green!) They had similar mods and his was consistently less than 1/10th faster in the qrtr than mine.
Being that LS1's like to rev a bit more than the LT1, the difference may be a bit more on an LS1 car though.
If I was in the market for an automatic it was in immaculate condition, low miles and at a great price, it wouldn't matter to me either way what gears it had. I'd jump on the 2.73 car just as well as a 3.23 car.
I don't think it really matters on the street or an "occasional" qtr mile car;
But..........................
If you're looking to squeeze ever bit out of it at the track or you just have a ng feeling that you should get 3.23's, then maybe you should hold out.
Old Jan 3, 2004 | 01:08 PM
camaro322hp's Avatar
exactly.
personally, i wouldn't decide to buy a car or not based on an option that i could change myself for such a low cost. that's why i always laugh at the car commercials that focus on what a great stereo the car comes with. :blah:
Old Jan 3, 2004 | 06:40 PM
Buffdaddy's Avatar
Just go for it!! I do not think it will make a huge differance and if it does I am sure you can make it up with mods. The car seems like a good deal!!!
Old Jan 3, 2004 | 06:51 PM
LeadSled1's Avatar
Thats a heck of a price. Keep the 2.73s and just get a bigger stall than you would with the 3.23. You will still have the same acceleration but you will also have better gas mileage when cruising on the interstate when the converter locks. Go with a 3400+3600 converter. People have run 11s with a 2.73 and it makes for a stronger rear for launching hard.
Jess
93 LT1's Avatar
Personally I have never seen a drastic difference between the 2 and believe me I have raced my fair share of 3.23's.If i was looking for a Z28, difiently I would want a 2.73 GU2. It may not be oustanding in 1st gear, but it pulls hard as hell in 2nd and 3rd, and you will leave no mercy for those clowns with 3.73's on the expressway. Thats for sure. I would buy it without a doubt. You put a stall converter in that..wow!
Old Jan 3, 2004 | 07:00 PM
psychocabbage's Avatar
I dont think that he will have any issues with his driveshaft or his top speed based on the info..
Top speed was limited to 118 or so if you had the cheesey non Z rated tires with the car.. Otherwise you got the 155 speed limit..
Old Jan 4, 2004 | 05:07 AM
Camaroman_94's Avatar
Go for it..
Old Jan 4, 2004 | 05:54 AM
Geezer powered's Avatar
yeah there no reason not to get a car based on it having 273's. You can always talk him down to in price and use that money for 342's or 373's and a converter.
Old Jan 4, 2004 | 03:49 PM
kcamaro6's Avatar
I say go ahead and buy it.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Queens94z28
Dec 20, 2014 09:11 PM
heavenly_six
Dec 10, 2014 12:23 AM
USAirman93
Nov 24, 2014 03:37 PM
