Shift pressure
Old Mar 29, 2012 | 06:04 PM
dboone2172's Avatar
Shift pressure
I have a performance tune install in my 2000 ss camaro, I can adjust the shift [AUTO ] pressure firmness but don't know witch way to go more or less and do you do all 4 gear
Old Mar 31, 2012 | 09:03 AM
Kevin Blown 95 TA's Avatar
Re: Shift pressure
I don't think you should mess with it, but...
You can increase shift firmness by lowering the numbers in the force motor current vs. temp vs. % throttle position, but you probably should only adjust the ones warmer than 20 deg C and keep in mind that you do not need it banging parts when you are just driving around, so less correction when you are not in the throttle as much.
RUENUF
Mar 13, 2016 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
