Service engine soon?
Old Nov 1, 2003 | 08:07 AM
Buffdaddy's Avatar
Unhappy Service engine soon?
Hey guys my service engine soon light came on yesterday and was wondering what the problem could most likely be. My ss is a 6spd with 43k miles on it. Also I work long hours so getting the car in will be difficult so if at all possible give me a time frame that I can work with. Thanks.
Old Nov 1, 2003 | 08:22 AM
SFB767's Avatar
I bet it's your catalytic converters, they're going bad.
My SES light came on when my car had your mileage and that's what was wrong with mine. I took it to Autozone and they scanned my car for free and I was running too rich in banks 1 and 2. I'm getting the catalytic converters and Y-Pipe replaced under the factory warranty on Tuesday. If your car has less than 80K on it, this service is FREE because it's under warranty. Just go to Autozone and have them run your codes.
Old Nov 1, 2003 | 01:32 PM
tailwindxr7's Avatar
There's not enough information there for anybody to make an educated guess towards what's wrong, so don't go buying any parts or replacing anything yet.
The first thing you have to do is get the code read. Autozone will usually do it for free. Once you know what the code is, come back and post the results, then someone can help with pinpointing the problem.
Old Nov 1, 2003 | 01:39 PM
krillanaross's Avatar
Is that true? or is it some sort of extended warranty? My SES light has been on for a while. I'm assuming its the cats so if my car has less than 80k its under warranty? If so is it only at the dealershiup the car was bought or any dealership?
Old Nov 1, 2003 | 02:07 PM
2001NBMZ28's Avatar
Cats are covered under "federal emissions" for 8 yrs/80K, regardless of where you bought the car. Bad cats show P0420 (driver's side) P0430 (passenger side).
Old Nov 1, 2003 | 02:09 PM
So it doesn't matter if I have an exhaust? That won't void the warranty?
Old Nov 1, 2003 | 08:10 PM
Buffdaddy's Avatar
I went to autozone and the problem is either o2 sensor or one of the cats. Tuesday I have it checked at a shop for the exact problem. I bought my car from an individual and I have no idea if it is under warrantly, but the federal commission allows any car under 80k miles for free work? Does anyonw know for sure about this? If it is the cats should I just get Random Tech high flow cats because eventually I want performance cats? Thanks.
Old Nov 2, 2003 | 06:42 AM
2001NBMZ28's Avatar
krillanaross - They shouldn't hassle you for the catback, if they try call another dealer.
Buffdaddy - Call a dealer and give them the code, if it's a bad cat they should replace it for free.
A friend of mine had one of his replaced free at 45K on his 2000Z, and he has a QTP electric cutout.
Old Nov 2, 2003 | 08:10 AM
Mikie's Avatar
You need to have it diagnosed with a tech II.
I dont see how anyone can guess its this or that. It can be one hundred and thirty five different things.
Get it scanned and be sure.
Old Nov 2, 2003 | 06:56 PM
slayer6x6's Avatar
Im pretty sure that in any obd2 car, the problem has to be emissions related to turn on the ses light.
Old Nov 2, 2003 | 09:53 PM
SFB767's Avatar
If you bought your car from a martian in outer space it would still be covered under the 80K warranty , just check your warranty book in your owner's manual, it will be there, it doesn't matter who you bought it from, as long as the car is 80K or under, they have to replace a bad catalytic converter.
cheapchevy
Apr 8, 2015 08:48 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Injuneer
Dec 15, 2014 09:36 AM
mspennyhughes
Nov 28, 2014 03:22 PM
transamtom
Aug 4, 2002 01:35 AM
