Air Lid to STAY CLOSED!?
Old Nov 1, 2003 | 09:31 PM
My00Camaroz28's Avatar
Hi all. I just bought a used Carbon Fiber Air Lid for my 00 Camaro Z28. I put it on correctly and everything is in place. Well, the problem is that i can't get it to stay shut! I close one down and then the other one won't go one...this is the same with both sides. Since I coulden't get them both shut I left one clamped on and the other one off. When I go to lift my hood after a while I noticed that it poped off...AGAIN. Is there any way to keep this thing closed, or any suggestions on how? (Yes I have messed around with it all night trying to get it in place, but no luck)
Old Nov 1, 2003 | 09:33 PM
(Can't get the clips to stay shut)
Old Nov 1, 2003 | 09:59 PM
tailwindxr7's Avatar
I had the same problem at first. Mine would clip down, but once the car moved the clips would come undone. It's not installed correctly.
It's a little hard to describe, but put all the tabs on the back of the lid inside their respective holes, then push down and back on it. They should almost "click" in place (sort of, not sure how to describe it,) and stay there.
Old Nov 2, 2003 | 12:04 AM
Jilly's Avatar
I have the same problem with the lid I got from tbyrnemotorsports.com Someone told me I need to cut the bellows.
Old Nov 2, 2003 | 12:33 AM
zoomjrl's Avatar
yeah, if you have a slp or custom bellow your going to have to cut it to make it fit. I just put my stock bellow back on until I get around to cuting the custom bellow
Old Nov 2, 2003 | 08:25 AM
Mine is the stock bellow.
Old Nov 2, 2003 | 12:10 PM
SSpdDmon's Avatar
Do you have a K&N or other aftermarket filter? If so, did you transfer that rubber gasket from your old lid to the new one? My friend had the same problem with the metal tabs coming off because he forgot to transfer the gasket.
Old Nov 2, 2003 | 02:13 PM
Not true. I ran my lid for months without the gasket (forgot to transfer it.)
It held down fine once it was installed correctly.
Old Nov 2, 2003 | 05:17 PM
...My filter is the stock one.
Old Nov 2, 2003 | 05:21 PM
BradleyPeart's Avatar
I had the same problem I was so pissed off. Then I realized that on the front of the lid, the piece on the front of the lid needs to go on the inside of the box lip. At first glance it looks to go on the outside, but try it on the inside. Hope you can understand that.
Old Nov 2, 2003 | 05:24 PM
It's dark outside now, but in the mourning i'll check it out again and see how I have it placed.
Old Nov 2, 2003 | 10:09 PM
JaysGone's Avatar
Im the guilty party who suggested to trim the bellows It doesnt matter what brand lid, what bellows it is. If the four tabs arent in the slots in the rear its not going to fasten in the front. Most of the time its incorrectly seated in the bellows and it puts pressure on the rear of the lid. Before trimming the bellows make sure its all the way back on the throttle body. Thats the side I had to trim to get my lid to fit right on both my 98 and my 02
QuickSilver02
Apr 7, 2015 11:12 AM
racecarz28
Mar 30, 2015 09:55 PM
mongoose=
Mar 22, 2015 07:22 AM
NED4SPD
Sep 16, 2002 10:45 PM
2000silverz28
Sep 7, 2002 01:48 AM
