Running HOT?
Old Sep 20, 2003 | 11:42 AM
LT-14me's Avatar
Running HOT?
Well, lately my car has been running at about 210*. Is this normal? SHouldnt it be more like 160*? on rainy days the heat from the motor fogs up the windshield. And when its sunny i can see the heat rays comming off the hood of the car! Is this normal? Or is my thermostat busted or something? Thanks
Old Sep 20, 2003 | 01:42 PM
crazyswede1027's Avatar
I know mine is always at 210 degrees. I heard on the board many times that the temp actually varies between 170 to 220 or something like that. The gauge is just designed to stay around 210 to not freak people out. Doesn't seem like it is that hot, but may want to have it checked out if you are worried.
Old Sep 20, 2003 | 02:48 PM
2001NBMZ28's Avatar
You have a 98 so your temp guage is real. Could be several things:
I'd check for low coolant, No fans - blown fuse, bad tstat, water pump, air in system, bad radiator cap, radiator blocked with something, leaking heater core, bad sending unit.
Old Sep 20, 2003 | 02:53 PM
chuck's Avatar
Why would it run 160º? The thermostat will be 195º or 205º, and the fans do not come until the motor is well above 160º. My '98 always ran about 210º.
Old Sep 20, 2003 | 05:58 PM
Ferocity02's Avatar
210 is nothing. Mine has gone up to 240, no biggy, well.... some funny smells maybe
Old Sep 20, 2003 | 11:58 PM
LT-14me's Avatar
ok so its nothing to really worry about? I really wasnt sure what it would be running temp wise. On my Monte i had a 355, and it ran at 160-180* so i was just asking thanks for the help
Old Sep 21, 2003 | 01:27 AM
AL SS590 M6's Avatar
Moderator
210° is pretty normal in any modern fuel injected car.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
