RPM's when shifting
Old Aug 3, 2003 | 10:26 PM
the1turkey's Avatar
RPM's when shifting
when i shift from park to drive in my A4 or drive to park the RPM's drop and take few seconds to work back up to where it idles it also does this when i brake on ocation i just got a new fuel filter becuase my car was running lean could this have anything to do with it or is this normal
Old Aug 4, 2003 | 12:33 AM
the1turkey's Avatar
TTT
Old Aug 4, 2003 | 12:51 AM
SpecForceZ28's Avatar
Are you due for Transmission fluid/filter change?
Old Aug 4, 2003 | 01:04 AM
the1turkey's Avatar
no clue does is that what it sounds like
some one else told me i could need new spark plugs since my car was running lean so long
Old Aug 4, 2003 | 01:13 AM
Hmm well just to be sure I'd change it, depending on how many miles you have since the last change, if at all, it was changed.
I must note, that changing the tranny fluid on the 4L60E is one pain in the ***.
Old Aug 4, 2003 | 01:17 AM
the1turkey's Avatar
thanks mabe i will i just had quick car replace the fuel filter and the ses light went off so i guess i'm not running lean anymore wounder how much the charge to do the tranny
i've gone through so much with this car and only had it for 2 months
Old Aug 4, 2003 | 02:13 AM
Hmm.
Your MAF could be descreened and ported.
That mod usually causes our cars to run too lean.
Here's a link to see if you have it:
http://www.installuniversity.com/ins...afapalooza.htm
I'm guessing you bought your car used.
Just a thought
Old Aug 4, 2003 | 02:23 AM
the1turkey's Avatar
well i don't think it's the MAF but u think i might need to change the tranny fluid anyone else second that i feel like a foster father to this camaro after taking it away from a guy that decided that it would look cool to install a batwing on top of the original spoiler and drill stright through the fiber glass guess he didn't like the way the RS side skirts on the spoiler looked ether cuz he removed those and left gaping holes after he put decales all over the fenders and burned the clear coat taking them off so i've spent 1000 on re fiberglassing the spoiler and body plus 800 on neglected maintenance 900 on paint 50 of 10 bottles of fuel injector cleaners 40 for the new fule filter now i have to mabe get the tranny fluid replace poor camaro srry just trying to vent
Old Aug 4, 2003 | 07:26 AM
the1turkey's Avatar
BTW you are suposed to check the tranny fluid when the car is pretty hot right and what should mine look like
Old Aug 4, 2003 | 07:48 AM
ChrisLS1Bird's Avatar
Please consider punctuation marks every once in a while. It's really hard to read a paragraph of run-on sentences and phrases.
Batwing? Ha ha. I hope you got a good deal on that one. That MAF is likely modded, but you may not need to worry about it.
Isn't there a screw on the TB that you can use to adjust the idle speed? It sounds like it needs to be backed out just a little. That may be all you need to do.
Old Aug 4, 2003 | 07:56 AM
the1turkey's Avatar
thanks srry about the punctuation. it's hard to type when your holding a 50lbs chunk of molded plastic shaped like a batwing in one hand and a bill from maaco in the other.
if anyone wants to recreate the batmobile let me know i've got the wing and my car did have the decales. who could do such a thing to a poor defenless car?
it would be helpfull if anyone could answer any of my other questions thanks
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
Apr 16, 2015 09:57 AM
97SSdude
Dec 31, 2014 07:43 PM
99blackz99
Aug 5, 2002 04:23 AM
