rich or lean...how do i check???
Originally posted by toykilla
I came here because my girlfriend bought a z28 so I was wanting to learn more about the cars. If you guys think it's a good idea to do a dyno run for o2 voltage then I doubt I will learn anything here. It saddens me that you big bad v8 ls1 owners know so little in general about cars. Seems like most of you know what you've heard or read. Most of you are running high 12's to mid 13's with mods. Uhh, last I checked the SS runs high 12's to mid 13's stock and the z28 isn't far off that mark. I can make a 16 second car run 12's...I KNOW
[B]It saddens me that you big bad v8 ls1 owners know so little in general about cars. Seems like most of you know what you've heard or read.
Get a clue.
Do you know how an air/fuel gauge works? First of all, they don't tell you **** at idle. They are suppose to go from rich to lean while at idle. It's a sign your fuel injectetion is working properly. You only get the correct readings while at WOT, for those of you that are stupid, while its floored.
If anyone is running 14.7v from an o2 sensor something is wrong. If you say your o2's are off in your car then that would be a good reason to use a EGT, exhaust gas temp. with it. The fact that someone said to get a dyno to find out o2 voltage is sad but its even worse that the rest of the Camaro world is backing it up.
If you get 14.7v from your O2 sensor yes its defective, the voltage range goes from roughly 0 - 1.1 volts from completely rich to completely lean. Yes, an EGT would be a good idea for someone looking for a more accurate reading. Things like timing can also effect your EGT though. For example, if your timing were theoretically near TDC (0° spark advance) you'd see that your exhaust manifold glows red and gets well over 1000°C VERY quickly. This really only happens in the test environment, I just used it as an example of how EGT can be effected by things other than A/F ratio.
Yup, you're right, I know nothing about cars.
Originally posted by 96fbirdA4
If you were to integrate your O2 voltage to get an average value for the signal just while cruising around, not at WOT, you would notice a trend of roughly where its running. The PCM would be trying to keep the A/F near stochiometry (14.7 A/F ratio). In theory it should be around 0.45 volts, I'm telling you that on an LS1 it won't be. The sensor will either read high or low, its not that accurate.
96fbirdA4 you are stretching it to think that the brainiac understands what intergration is.. much less knows how to do it and what it can tell him.. LOL
As for the "you don't know jack about cars" comments, I think they speak for themselves.
And which major automaker research and development facility do you work for? Honda R&D here, I can scan my badge in if you'd like to see it.
http://www.geocities.com/sigmachi03/asimo.html
well i DONT know everything about cars and my LS1.
i know more than most people.
so yea...
thanX again for the responses.
when im not broke ill look into gettin dynoed again.
Oh and whuts different about a wideband?
edit:
most people meaning the non car junkies unlike people on this board
so yea...
edit:
But these Tech posts are almost as much fun as the Lounge !!
Anyway, what is a wideband ??
And, for argument's sake
the only way I found out about my A/F ratio was thru a Dyno test - $ 35.00 for 2 pulls.
That wasn't the reason I dynoed, though .
Britt
the only way I found out about my A/F ratio was thru a Dyno test - $ 35.00 for 2 pulls.That wasn't the reason I dynoed, though .
Britt
I honestly think that he knows a decent amount about cars. If he knows enough about what I'm talking about, he should agree with me.. In my first post I didn't point out that I was talking about an average value from the O2 sensor. If you were to hook up the line from your O2 sensor into an oscilloscope it would look somewhat like a messed up squarewave. You would see a bunch of zero-crossings (with zero being stochiometry 0.45v) because the computer keeps going rich-lean-rich-lean-rich-lean trying to run at stochiometry. He was 100% correct about that.
Originally posted by My84Z
toy in case you didn't notice there were no ignorant remarks untill you said one so if you want poeple to be nice to you smarten up and be nice to others.
well since you didn't understand what i said i will say it in plaing terms for you if you act likt a **** wich you have so far noone will be nice to you and will say stupid things about you so instead of being the idiot that you are be a good boy. ok i hope this gets through to your head i know it is tough with all those nawsssss ideas's and stickers your dreaming up.
ummm actually smart *** that was my last car and that did mid 12's your 4 banger doesn't so that does it exactly my new car is a dead stock 2000 ss and i have no need to be fast cause it is still 100000000 times better looking than yours.
.................................................H ERE....................................
...IT............................................. ...............................................
.................................................. .............COMES..................
SHUT THE **** UP MORON...
first off i don't believe you and you havn't even said what your car was and second off my car only had exhaust intake and rr's so it was all bolt ons i didn't need very much so if you car is the **** what is it big mouth?
