Rebuilding LS1 Advise
Old Sep 27, 2011 | 08:59 PM
downwithmustang's Avatar
Little over a year ago I spun an bear in my motor. I have over 100k miles on the motor. Should I rebuild, buy a used block (transfer parts over) or pick up a used LS1? I not looking to spend a lot of money.
Old Sep 28, 2011 | 01:08 AM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: Rebuilding LS1 Advise
Are you going for a stock rebuild or wanting to add some performance?
Old Sep 28, 2011 | 06:29 PM
I thinking about adding aftermarket pistons.
Old Sep 28, 2011 | 08:18 PM
raulz28's Avatar
My friend bought a 98 T/A with a blown engine and we threw in an LQ4(he thought it was an LQ9 when he bought) he bought for $900 but the guy threw in an engine stand and a cherry picker. They make very good power and also have the potential to be stroked to a 408 which is why my friend decided on it with my persuasion. I would go with a 6.0 iron block if I were you. Just my 2 cents
Old Oct 17, 2011 | 11:03 AM
Antz97ZNJ's Avatar
So many options man.Stroker/heads,cam/LQ4-9 rebuild etc etc...while your in there I would add a lot more higher performance parts then pistons
Old Oct 18, 2011 | 01:37 PM
WhiteHawk's Avatar
I would just buy a junkyard motor. If you can do the labor yourself, you should be able to get by under $2000.
If you do a rebuild, it is easy to get $500-$1000 in machine work. If you go aftermarket with a crank, pistons, and rods, figure about $2500 for the rotating assembly and rebuild parts. At that point, it seems like a waste to put stock heads on it, so tack on another $2000 or so.
Shoot me a PM if you want (I am in Warren) if you need a motor - I know a junkyard that has a low mile LS1 right now.
-Geoff
sherwinZ28
11
Aug 15, 2015 05:38 PM
Jocofire1
Aug 7, 2015 03:16 PM
wesley81
Jul 27, 2015 11:31 AM
mrwz28
Jul 8, 2015 09:11 PM
