Rear main or oil pan gasket?
Old Jun 19, 2014 | 01:29 PM
k.olson's Avatar
So I have a 2001 z28 and I've noticed an oil leak right around where the transmission and the oil pan meet. It's not much but it's getting annoying. I think it's the rear main seal but I heard that it could also be the oil pan gasket. Is there any way to tell the defference? Thanks for the help.
Old Jun 21, 2014 | 07:01 PM
BandDirector Blk98ZM6's Avatar
Re: Rear main or oil pan gasket?
Unfortunately, the only way to tell if it's the rear main seal is to pull the transmission and inspect. Is it dripping out of the little rectangular hole at the bottom of the transmission?
Old Jun 23, 2014 | 03:28 PM
MachinistOne's Avatar
Make it easy on yourself and just order a replacement back-plate with rear main seal already installed from the dealer, it's less than $50. Pull out the transmission, remove the back plate and install the new one with some grey silicone at the corners.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
