Rear End Bolts, how many Ft-Lbs?
Old 04-12-2003, 03:38 PM
Ferocity02's Avatar
I'm changing the oil in the rear end and need to know how many ft-lbs to torque the 10 bolts down to.
One more thing, when putting the liquid sealant onto the gasket, should I put it on both sides of the gasket?
Ferocity02 is offline
Old 04-12-2003, 04:54 PM
#7's Avatar
I put mine @ 22ft/lbs,manual says 20-22 you decide. sealant thin coat both sides.
#7 is offline
Old 04-12-2003, 04:59 PM
Ferocity02's Avatar
Since people in this forum are more responsive than in the appearence forum, is it safe to paint the cover with some high temp paint? It's looks so bad all rusted and crap.
Old 04-12-2003, 05:16 PM
#7's Avatar
No it dont hurt to paint it.It doesnt have to be high temp but it'll work. When painting anything prep is the most important.You should use a degreaser on the thing or a good solvent.Wet sand w/ some sand paper I think 180 to remove any corrosion wash .Best you get some primer good stuff.But I done it w/o primer before on my other vehicles. Paint light coats at a time as to not run it.
Or just wait awhile till next oil change and get a TA girdle before.I'm gettin that for looks and xtra strenghth.
You could find a chrome one.
#7 is offline
Old 04-12-2003, 08:10 PM
Ferocity02's Avatar
Should I use some thread lock?
Old 04-12-2003, 11:34 PM
norcalstreet's Avatar
Yes, use a weaker kind. Not the red type.
norcalstreet is offline
Old 04-13-2003, 09:46 AM
SteveC's Avatar
Smile
I personally would NOT use any type of thread lock on the differential bolts. Torqued at 22 lbs, and taking into consideration the movement in that area (none), they will never back out.
When I swapped my stock cover for the TA girdle, I had it sand blasted, primed and painted flat black, with 2 yellow strips running down each side. Came out killer.
SteveC
SteveC is offline
10-31-2016 11:09 AM
Chet1185
02-04-2015 09:51 PM
jcamaro95lt1
01-24-2015 08:21 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: Rear End Bolts, how many Ft-Lbs?
