Rattling inside Catalytic converter...
Old Mar 15, 2007 | 11:53 PM
krazykorean35's Avatar
wondering if anyone has had a similar problem with what sounds like a loose bolt/piece of metal in the catalytic converter...thanx!
Old Mar 16, 2007 | 12:01 AM
Capn Pete's Avatar
Yup! Do a search in this forum under keyword "catalytic" and you'll find a few other threads about the same thing. Time for a new cat .
Old Mar 16, 2007 | 12:29 AM
damn...thanx!...mb i should just cutem out...let those prius drivers do the saving the environment thang
Old Mar 16, 2007 | 01:06 AM
do you know if im doin any more damage to my setup by not fixing this right away?? or any sorta painless ways to gut the cats on an ls1?
Old Mar 16, 2007 | 01:35 AM
Capn Pete's Avatar
If you were anywhere other than Cali., I'd say gut the cat's and be on your way ..... but you've gotta pass pretty strict emissions testing, don't you? I think your best bet is replace the bad cat (for what they cost).
Old Mar 16, 2007 | 01:05 PM
Kraest's Avatar
Retired
Chop it off.
Old Mar 16, 2007 | 01:27 PM
2000GTP's Avatar
I see you are in California. Not sure how strict emissions are in your particular neck of the woods, but I would exercise caution with hacking off a cat.
Old Mar 16, 2007 | 01:54 PM
yeh ca is the **** of emissions, but we gotta guy that accepts cash only for smog!...what do i do with the sensors on the cats if i decide to just lose them?? thanx 4 all the input
Old Mar 16, 2007 | 02:01 PM
2000GTP's Avatar
Either have the PCM tuned or plug an 02 simulator into the rear 02 sensor harness connector to avoid an SES light.
Old Mar 16, 2007 | 02:24 PM
myslowcamaro's Avatar
there was a "problem" notice sent out to many, not a true "recall" notice. call the dealer, it might be covered still
http://web.camaross.com/forums/showthread.php?t=508516
Old Mar 16, 2007 | 03:40 PM
2001NBMZ28's Avatar
Believe the extended warranty on the cats is only for 00-02 cars w/stock cats. Dealer will freak when they see SLP LTs.
Old Mar 16, 2007 | 09:49 PM
Capn Pete's Avatar
Exactly!! A) wrong year, B) wrong exhaust!! I don't think the dealer will be helping you out any on that one?!
Old Mar 18, 2007 | 04:09 PM
so after a couple days the rattling has become less frequent and a second rattle has started further down in my exhaust...it possible for the honeycomb in the cat to blow out of the exhaust??
Old Mar 19, 2007 | 09:15 AM
AL SS590 M6's Avatar
Moderator
yes
Old Mar 19, 2007 | 01:39 PM
ws6transam's Avatar
More than likely it'll end up in your muffler and that is where it'll stay, blocking your airflow.
autoxr166
Sep 25, 2015 04:21 PM
colts0455
Sep 22, 2015 02:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
