quick cig lighter question. Trouble shooting
the extra outlet on the bottom right of the dash... can it double as a cigerette lighter? im testing it to see if its working... I put the cig lighter plug in it but it didnt heat up.
IM trouble shooting some stuff..
my cig lighter plug works (heats the lighter) but my radar detector and g tech do not work in it... and they dont work in the spare outlet either...
S
S
you need to check the fuses in your G-TECH and your V1. Also spend 10-20 bucks and go to radio shack and get a volt meter. make sure you are getting 12v from your cig lighter outlets. Also check the fuses to your outlets in the fuse pannel. Good Luck
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 08:50 AM
