Questions about ls1 heads
Old Mar 26, 2007 | 11:19 AM
Billet ss's Avatar
Will 99 ls1 heads fit a 2000 without mods? and if there milled 30 thousands what would the compression be with stock gaskets.Are 2.05 valves a good size?
Old Mar 26, 2007 | 11:37 AM
Kraest's Avatar
Retired
Yes.
Around 11:1 ?
Depends on the application. You'll have piston to valve clearance issues with a big valve like that and a milled head.
If you don't have an aftermarket cam already, there's no point in switching heads.
Old Mar 26, 2007 | 11:45 AM
Billet ss's Avatar
I plan on useing the cheater cam with those heads,with do I have to do to make them work on the stock shortblock?
Old Mar 26, 2007 | 01:02 PM
Kraest's Avatar
Retired
You shouldn't have any PTV problems with a small cam like the Cheater, but check to be safe if you're going with milled heads, a 2.055 valve and stock pistons. Worst case = flycut the pistons.
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
ChrisFrez
Nov 23, 2014 10:33 AM
