Question on true duals and suspension
Old Nov 30, 2003 | 12:26 PM
GoFast908Z's Avatar
Member
I'm doing true duals in January, but for traction help, I need a torque arm.
My question is: Do i need to do the torque arm before welding up the true duals? It looks like there may not be enough room to fit it over the x-pipe if I did the duals first.
any thoughts?
Old Nov 30, 2003 | 12:33 PM
CRZYPWR's Avatar
Oh ****..Thats a good question. I have mine on already ...and I dont know if I can fit that on now.
Old Nov 30, 2003 | 12:48 PM
jm8881's Avatar
Re: Question on true duals and suspension
any thoughts?
If you use an x or h pipe it won't be true duals. True duals are two separate pipes. The sound is way better with true duals compared to an x pipe exhaust (imo). But they say a true dual setup will decrease performance but that decrease would be so small that the sound you get from it would overshadow the loss.
Old Nov 30, 2003 | 12:53 PM
Aklaim's Avatar
Re: Re: Question on true duals and suspension
Wrong. If you add an H or X pipe it is still true duals. You have 2 pipes going back untill they cross, and guess what you have after that........2 pipes! If you want the absolute best performance, go with the X pipe. But I would do the torque arm frist, just to be sure. Any good exhaust shop can route it around the torque arm if needed.
Old Nov 30, 2003 | 01:03 PM
jm8881's Avatar
Yeah, you'd have dual exhaust but not true duals. True duals never intersect each other which is why that system is called true. If you have an x or h pipe, sure you have dual exhaust, but it isn't ture dual exhaust. The x or h pipes will perform better than a ture dual system.
Old Nov 30, 2003 | 01:05 PM
Aklaim's Avatar
right.....
Old Nov 30, 2003 | 04:32 PM
CRZYPWR's Avatar
It is true dual exhaust... X pipe or H pipe.
Old Dec 1, 2003 | 01:21 AM
AL SS590 M6's Avatar
Moderator
The term "true duals" comes from the fact that most any car or truck made after the 1960s with 2 tail pipes has "fake duals". A single I-pipe feeding a dual outlet muffler.
Any exhaust that starts out as 2 pipes and continues as 2 pipes all of the way to it's exit is a true dual exhaust irregardless of whether they intersect in an H or X on the way there. It's still 2 pipes from front to back. Hence duals.
Old Dec 1, 2003 | 01:31 AM
Aklaim's Avatar
Werd.
Old Dec 1, 2003 | 08:12 AM
jm8881's Avatar
Well it looks like I'm the wrong one here. I was just going buy the local exhaust shops here. When I took my older camaro and later when I took my ramcharger to the shop and had duals put on he asked if I wanted actual true duals or an X pipe. So I took it that the expert new what he was talking about. Silly me! Anyways thanks for setting me straight.
Old Dec 1, 2003 | 07:11 PM
GoFast908Z's Avatar
Member
so I should do the torque arm first then?
now all that is left to decide is 2 1/2" or 3" (a highly disputed topic, that I don't want to discuss here. I'll just do research).
and 2nd, how to weld up a cutout right before each muffler....
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
guionM
9
Aug 29, 2002 01:48 PM
