QUESTION on gears?
Old May 23, 2007 | 06:54 PM
Snugans310's Avatar
Exclamation QUESTION on gears?
What do you guys think about gears on a 2002 camaro ss should i go with the 3:90 or the 4:10 i have a 6 speed and i love my gas mileage what do you guys think ohhhhhhhhhhh i like freeway racing top speeds
Old May 23, 2007 | 07:03 PM
rickjames343's Avatar
the higher the gear ratio, the higher the acceleration, but generally the lower the top speed as well.
Old May 23, 2007 | 09:31 PM
bombebomb's Avatar
I read a topic eariler, and it was a huge debate over pretty much what your asking for. Id guess 3.90 from what iv read if your into the highway thing.
Old May 23, 2007 | 09:43 PM
SSpdDmon's Avatar
If long term plans involve heads/cam and what not, I'd go 3.90. With 4.10's, you'll be running out of gear by the traps assuming you're doing 120mph. If bolt-ons only are the idea and you'll be trapping 112mph or less, you may be able to get away with 4.10s. Then again, if it were me, I'd set that money aside and start saving for a Moser. Throwing performance parts at the 10-bolt in an M6 car is like pissing into the wind.
Old May 23, 2007 | 09:49 PM
WS6NIGHTMARE's Avatar
I think 4.10's will put you in 5th just in a 1/4 mile run. 3.73's are going to be a better choice for your freeway bombing and still being able to run the 1320. Either one is going to drop your mileage though.
Old May 23, 2007 | 09:51 PM
Kraest's Avatar
Retired
3.73 or 3.90 based on your power level and what you want to do.
4.10s are good for around 125 mph in the 1/4 in 4th with 26" tires.
Old May 24, 2007 | 10:54 AM
Capn Pete's Avatar
Yeah, for what you want to do? Probably 3.73's, or 3.90's at most.
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
