Putting my LS1 back together... trying to figure out where a couple lines go
Old 01-21-2009, 11:15 PM
IRONFIST's Avatar
I guess my memory isn't as good as it should be, I should know better then to take the thing apart without pictures.
Can you guys help me out and tell me where these lines go.
One of them is PCV I think from the intake.
IRONFIST is offline
Old 01-22-2009, 03:52 PM
johnny6's Avatar
If i'm not mistaken that first one goes behind the intake where the other very small plastic line hooks up....Not too sure though because you have the LS1 intake. Isn't the 2nd one a brake booster line? The one that goes behind the master cylinder?
johnny6 is offline
Old 01-22-2009, 07:11 PM
IRONFIST's Avatar
Here's a better picture of it, after pulling it out.
IRONFIST is offline
Old 01-22-2009, 07:14 PM
danhr's Avatar
that 2nd one goes into the back of the driver's side valve cover.
danhr is offline
Old 01-22-2009, 07:25 PM
johnny6's Avatar
Yep good call. forgot all about the drivers valve cover. The first one goes in the back of the passenger side valve cover i think. Just look at the back passenger valve cover and check to see if you have a hose hooked up, if not that's where it goes.
johnny6 is offline
Old 01-22-2009, 08:14 PM
IRONFIST's Avatar
Thanks a lot man
IRONFIST is offline
smokin25th
01-01-2015 09:06 AM
Jazsun
12-29-2014 12:14 PM
cmdeshon
12-27-2014 10:06 AM
Mad_Ice
07-29-2002 09:44 PM
Manaz101
07-18-2002 09:39 AM
Quick Reply: Putting my LS1 back together... trying to figure out where a couple lines go
