Project Turbo GTO @ VRE
Old Nov 13, 2007 | 02:24 PM
Eric@Victory Racing's Avatar
Victory Racing Engines 408cid LS1
Victory Racing Engines Custom Rear Mount Turbo System
RPM Level 5 Transmission
Textralia Exo-Skel Clutch
NX Wet Nitrous Kit
Pedders Extreme Suspension Package
Kaaz Limited Slip Diff
DiffTechs Stub to Hub
Start Up Video
Old Nov 13, 2007 | 02:51 PM
cjmatt's Avatar
I want Dyno Numberrrrsssssss!!!!!!
and that thing washed and waxed
Old Nov 13, 2007 | 04:28 PM
I hear ya. We are building custom fender flares for it to put 315's on the rear, a new hood and some other cosmetic stuff so the was and wax is on hold for a while. We will be dynoing the vehicle on Friday as long as everthing stays on schedule.
Old Nov 13, 2007 | 06:48 PM
Dragoneye's Avatar
Impressive. It's also nice to see others trying out the rear-mount Turbo design besides STS.
Dyno results needed for sure! Great job!
Old Nov 13, 2007 | 07:01 PM
Greed4Speed's Avatar
Nice. That should sneak up on a few people.
Old Nov 14, 2007 | 08:34 AM
Kraest's Avatar
Retired
Why the rear mount?
Old Nov 14, 2007 | 09:33 AM
cjmatt's Avatar
Originally Posted by Kraest
Why the rear mount?
the car previously had an STS system that had basically disintegrated, so it was redone from the ground up, all stainless, gorgeous, and basically indestructible
Old Nov 14, 2007 | 09:56 AM
Correct...
The vehicle had a STS Turbo Kit on it for about 2 years and it was completely rotten with holes the size of quarters everywhere. It was less expensive to rebuild the a rear mount kit instead of fabricating a whole new standard turbo kit.
Old Nov 14, 2007 | 10:08 AM
Rice Killer87's Avatar
Freakin sweet!!
I love that intercooler behind the factory mesh....gotta look a couple times to see it
Old Nov 16, 2007 | 03:13 PM
RealQuick's Avatar
Nice work Eric!
Old Nov 17, 2007 | 04:27 AM
robb4964's Avatar
Custom flares for 315's? YOU GUYS ROCK!!!!!!!! Keep up the good work
Old Nov 19, 2007 | 03:46 PM
Dyno Video
Old Nov 19, 2007 | 10:18 PM
USA1Camaro's Avatar
What numbers did you end up on the dyno run?
Old Nov 20, 2007 | 07:22 AM
AL SS590 M6's Avatar
Moderator
Yeah what good is the video without the numbers??
Old Nov 20, 2007 | 07:28 AM
We had some issues on they dyno, and hpe to have them resolved soon. The new Textralia Exo-Skel clutch started slipping right about 3800rpm, and the boost was bleeding off from 8psi to around 5psi. All and all a waste of time on the dyno, but have a baseline of 550/510 @ 8psi and 12 degrees of timing. After Thanksgiving we will have the vehicle back to swap the clutch and plan to hit the rollers again. This time with meth, nitrous and about 20psi.
On a somewhat positive note the owner made a cross state drive on Friday and got a stunning 24.6 miles to the gallon.
