Problems-Any solutions
Old Jun 28, 2009 | 09:04 PM
bwarren337's Avatar
I have a 99 z28 m6 and first off my car has been trying to over heat on me and i can hear air bubbles in the radiator. I have tried many of times to get them out but still no luck....
2nd my car is throwing a MAF Circuit low input code (P0102) and A 1-4 Upshift solenoid circuit Malfunction code (P0803)..
I dont have any Cats on my car and it is not throwing any codes for the O2 sensors.... If anybody has any suggestions or ways to fix thse problems it would be greatly appreciated...
Old Jun 29, 2009 | 09:32 AM
2001NBMZ28's Avatar
The MAF and skip shift are on the same circuit - check and see if the ENG SEN fuse is blown. For the overheating make sure the radiator cap is holding pressure.
Old Jun 29, 2009 | 09:36 AM
WhiteHawk's Avatar
Check your thermostat for overheating. If you are in the Detroit area I think I have one laying around you can have.
-Geoff
Old Jun 29, 2009 | 12:17 PM
bwarren337's Avatar
if i replace the ENG SEN fuse what are the chances it is going to blow again...
Tennessee..
Old Jun 29, 2009 | 12:39 PM
bwarren337's Avatar
i checked my ENG SEN it was blown
Old Jun 29, 2009 | 01:10 PM
2001NBMZ28's Avatar
Try replacing the fuse and see what happens, most likely cause is a shorted 02 sensor harness against a header - if you have LTs. If not, it's something else on the circuit. I should've mentioned in my earlier post that the H02S' and reverse lockout solenoid (M6) are also on that circuit.
Old Jun 30, 2009 | 11:34 AM
bwarren337's Avatar
anybody have any idea why its not throwing O2 codes if i dont have any in???
generaldave
Sep 25, 2015 06:48 PM
Jul 17, 2015 02:47 PM
SubsAnDubs
Mar 29, 2003 04:27 PM
ixd97z28
Feb 21, 2003 03:30 PM
Johnny Hunkins
3rd Gen / L98 Engine Tech
21
Aug 26, 2002 09:42 PM
