Pro 5.0 NOISE
Old Aug 26, 2003 | 10:06 PM
DavidSS's Avatar
Pro 5.0 NOISE
I just installed my Pro 5.0 and Lou's short stick yesterday. I love it. But I've noticed A LOT of noise especially in first gear. Anybody had this problem??? Anybody got any suggestions?
David SS
Old Aug 26, 2003 | 10:47 PM
demonspeed's Avatar
Like what kind of noise? Grinding noise or road noise? Is it only when accelerating or just cruising? Low rpm or high?
Old Aug 26, 2003 | 10:50 PM
DavidSS's Avatar
It's happeneing when im accelerating, at high rpms. It's almost like transmisson noise.
Old Aug 26, 2003 | 11:05 PM
Omega9's Avatar
Thumbs up
You'll get transmission noise with the Pro 5.0 because the stock rubber boot is eliminated. I like to hear what my transmission is doing
Old Aug 26, 2003 | 11:07 PM
DavidSS's Avatar
Thats what i figured it was. Is there anyway to quit it down??? It's loud, a lot louder then I want.
Old Aug 26, 2003 | 11:18 PM
blacknight's Avatar
Two things you can do.
1st. Get a piece of rubber to stick between where the stick mounts.
sec. Get some gasket material and make a template the size of where the shifter mounts and glue that between the shifter base and trans. I would do both if it really bothers you.
Old Aug 27, 2003 | 12:18 AM
chpmnsws6's Avatar
you can also buy a louder exhaust
Old Aug 27, 2003 | 01:42 AM
AL SS590 M6's Avatar
Moderator
Re: Pro 5.0 NOISE
David SS
How often and how long are you in 1st gear? Mines a little noisy too but mostly in 3rd gear it's the price that you pay for performance.
Old Aug 27, 2003 | 08:59 AM
DavidSS's Avatar
Just depends on how I'm driving it. Sometimes not long, other times till i hit 5500 rpms.
Old Aug 27, 2003 | 09:34 AM
cals400ex's Avatar
the noise is normal. when i installed mine i installed a fairly thick rubber gasket between the base of the shifter and the tranny. so i don't know how much this helps since i put it there when i installed the shifter. i do hear a little grinding/rattleing noise if i take off really slow in first or if i am at a really low rpm. i also hear noise at higher rpm's too. its a great shifter though.
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
