Possibilities?
Old Apr 7, 2007 | 07:44 PM
thewolfman0351's Avatar
Possibilities?
Got a 2002 z28 5.7L, if possible I want to build the biggest engine i can that will fit in it's engine compartment. What is the largest build while maintaining the ability to run off 93 octane? If anyone can throw me some advice, it would be greatly appreciated. Kinda new at this stuff and just need a little kick start help ya know, luckly i'm a fast learner
Old Apr 7, 2007 | 07:47 PM
teke184's Avatar
some one posted a link to a new block bassed on the LSx design that has the capabilities of 511ci
but typical strokers these days are using the ls2 blocks and the new 6.2L block.
some of the typical "big" engines are 402, 408 and 413ci
you can also go up to the 427 that VRE makes...check them out on the vendor list
Old Apr 8, 2007 | 04:13 PM
Kraest's Avatar
Retired
Using the block you currently have, you can go to 383 ci.
If you're going aftermarket, your limit is as big as your wallet.
Mike
Old Apr 8, 2007 | 08:39 PM
Capn Pete's Avatar
An LS1 block can be re-sleeved (and with a nice long stroke) out to ~454 c.i. . Then if you get into that LSx block directly from GM ... ... 500+!! Insane!
... and it all fits exactly the same as stock!! Not like trying to stuff a big-block in where a small-block barely fits .
Old Apr 8, 2007 | 09:06 PM
Bayer-Z28's Avatar
Warlock block or the new LSX block... The LSX block has the capability to have a max displacement of 572 cid or something like that.
Look under ENGINE at www.ls1speed.com
Ericksd
Jan 20, 2016 06:07 PM
PopoFormula
Oct 12, 2015 04:19 PM
jackpawt883
Sep 10, 2015 08:53 PM
ZXXVIII
Sep 1, 2015 04:14 PM
97SSdude
Aug 21, 2015 09:36 AM
