ported throttle body and smooth bellow
Old Mar 28, 2005 | 06:54 PM
Njgunslinger's Avatar
You guys think that helps at all?
Old Mar 28, 2005 | 07:21 PM
Schmidt519's Avatar
Re: ported throttle body and smooth bellow
Do you consider 1 HP worth it for the smooth bellow. The throttle body is not necessary unless your making over 500 HP.
Old Mar 29, 2005 | 06:26 AM
teke184's Avatar
i doubt the bellows is even gonna get you that much.
it's 99.9% visual mod
the ported TB...by looking at the unit, and doing the machine work myself. i can tell you that there should definatly be a difference in part throttle response.
the first 5-10% of throttle opening, there is a significant increase in the air that can flow into the TB after porting.
but once you exceed that first few percent it is only gaining from the widening of the cross section of the TB. which is only about 2mm in added diameter.
so WOT gains are minimum, but i think around town it would improve response.
Old Mar 29, 2005 | 06:58 AM
teke184's Avatar
been meaning to make a drawing of how the porting works.
so here you go
i know a machinist who will port a TB for $50, only problem is he doesn't have units as core...so you're car will be TB-less for the time it takes to machine it.
Old Mar 30, 2005 | 08:20 PM
Cstick's Avatar
TB- Yes (avg at least 5RWHP)
Bellows- just for looks
Old Mar 31, 2005 | 07:01 PM
luv2spd's Avatar
On a cammed car the ported tb is easily worth 5-7 hp.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
