Ported L92 Heads #'s?
Old Mar 21, 2007 | 12:46 PM
GreenDemon's Avatar
Question Ported L92 Heads #'s?
Anyone have a flow chart for ported L92 heads yet? All I can get is rumors of peak flow #'s, but I was interested in the #'s for the entire lift range...
Old Mar 21, 2007 | 01:20 PM
Kraest's Avatar
Retired
They start off with huge intake runners and end up with even "huger" intake runners.
I haven't seen any "impressive" numbers with them yet. You need lots of cubes and lots of cam to make them work well.
Old Mar 21, 2007 | 08:09 PM
RE AND CHERYL's Avatar
I beleive they only work on a 4.0" bore
Re'
Old Mar 22, 2007 | 08:28 AM
Kraest's Avatar
Retired
Re'
4" or larger.
Old Mar 23, 2007 | 10:12 AM
GreenDemon's Avatar
I wasn't planning on using them on an LS1, I just thought they would be a good bargain for a budget LS2 4xx buildup. So far I've seen several vendors offer ported versions, but they haven't been offering up any #'s on them. I would imagine the large volume runners would be acceptable on that.
Old Mar 23, 2007 | 10:20 AM
Zigroid's Avatar
lookie here
Originally Posted by Jason 98 TA
Guys here's the dyno sheet from the 418 l92 stroker complete with l92 heads & l76 intake!
This is the engine that made 640 flywheel horsepower a week or two ago. I'll try to post up the dyno figures for the engine dyno later today.
Here's the specs on the motor & car:
TSP 418cid L92 Stroker
4.080" Bore
4" Stroker
Precision Race Components 6.2l Heads
PRC Platinum Spring Kit
Texas Speed 251/259 Camshaft 110+3
ASP Underdrive Pulley
Stock 6.2l Intake w/ stock 6.2l injectors
1 3/4" Headers
Borla Catback
3.90 Gear 12 Bolt
The engine dyno tests were done with 1 7/8" headers. Unfortunately the customers car is running 1 3/4" headers, but the car still makes very good power. If memory serves me correctly the engine is just a little bit over 11:1. We dyno tested several different camshaft options on the dyno, but decided to leave this one in to see how she drives
Chassis Dyno Results:
those huge runners dont seem to have a problem producing kick *** low end torque, provided you don't have a huge *** cam like the above. this is the first build ive seen that can actually rev, though. Id rather go with the 242/250 cam they tested previously that made 630 on the engine dyno (gave up 10 hp) but made a ton more torque down low.
Old Apr 2, 2007 | 04:40 AM
Travis.Bill's Avatar
Originally Posted by Zigroid
lookie here
It seems to me l92's on a 400+ cube engines have a habit for putting down 550 to the wheels and im glad because that is what im putting together.
Old Apr 2, 2007 | 08:46 AM
Kraest's Avatar
Retired
I've seen 480-530 rwhp 90% of the time. It all depends on the combo. These heads like big cams as shown in the above dyno graph.
Old Apr 2, 2007 | 08:50 AM
Kraest's Avatar
Retired
GreenDemon:
Here's some numbers:
http://www.ls1tech.com/forums/showthread.php?t=686006
Old Apr 3, 2007 | 08:58 AM
GreenDemon's Avatar
Thanks.
Looks like they're still trying to figure out what the best budget combination is.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Wilson
Jul 21, 2002 05:08 PM
