Ported L92 Heads #'s?
I wasn't planning on using them on an LS1, I just thought they would be a good bargain for a budget LS2 4xx buildup. So far I've seen several vendors offer ported versions, but they haven't been offering up any #'s on them. I would imagine the large volume runners would be acceptable on that.
Originally Posted by Jason 98 TA
Guys here's the dyno sheet from the 418 l92 stroker complete with l92 heads & l76 intake!
This is the engine that made 640 flywheel horsepower a week or two ago. I'll try to post up the dyno figures for the engine dyno later today.
Here's the specs on the motor & car:
TSP 418cid L92 Stroker
4.080" Bore
4" Stroker
Precision Race Components 6.2l Heads
PRC Platinum Spring Kit
Texas Speed 251/259 Camshaft 110+3
ASP Underdrive Pulley
Stock 6.2l Intake w/ stock 6.2l injectors
1 3/4" Headers
Borla Catback
3.90 Gear 12 Bolt
The engine dyno tests were done with 1 7/8" headers. Unfortunately the customers car is running 1 3/4" headers, but the car still makes very good power. If memory serves me correctly the engine is just a little bit over 11:1. We dyno tested several different camshaft options on the dyno, but decided to leave this one in to see how she drives
Chassis Dyno Results:
4.080" Bore
4" Stroker
1 3/4" Headers
Borla Catback
3.90 Gear 12 Bolt
lookie here
those huge runners dont seem to have a problem producing kick *** low end torque, provided you don't have a huge *** cam like the above. this is the first build ive seen that can actually rev, though. Id rather go with the 242/250 cam they tested previously that made 630 on the engine dyno (gave up 10 hp) but made a ton more torque down low.
I've seen 480-530 rwhp 90% of the time. It all depends on the combo. These heads like big cams as shown in the above dyno graph.
Looks like they're still trying to figure out what the best budget combination is.
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
