Port and Polich yourself???
Old Jun 22, 2005 | 08:49 PM
poxz's Avatar
How hard is it to port and polish your own MAF and TB?? ANd what about the Manifold. Is there any web sites that give step by step directions.
Thank you ahead a time.
Old Jun 23, 2005 | 07:23 AM
teke184's Avatar
Re: Port and Polich yourself???
maf is said to be a waste of time, and actually causes problems with tuning.
and the screen on it can keep junk out of your engine. i somehow sucked a small hose clamp into my engine, and since i have maf ends there was no screen to stop it. caused ALOT of damage.
as for the TB...minimal gains, but for something that is nearly free. some claim drivabiltiy problems after doing it. i ported mine on my dad's lathe in a machine shop, and have had no problems.
and how do you port an LS1/LS6 intake? they already flow pretty well
Old Jun 23, 2005 | 09:01 AM
SSpdDmon's Avatar
Zaino! Put a healthy coat on the inside and you'll get an extra 15rwhp!
Old Jun 23, 2005 | 10:44 AM
Bert02SS
Guest
Posts: n/a
Naw, the Zaino option is WAY too expensive!
poxz's Avatar
I was actualy wanting polish more than port. I mainly wanted to polish the TB, MAF, and Manifold for looks only, I just wanted to see if it would be easy to port while I was at it.
So I will refraze the question.....
Does any one have any instructions on polishing the maf, tb and Intake (or paint the intake)..
I want to look like this http://www.cardomain.com/ride/314999/3.
Thank you.
Old Jun 23, 2005 | 12:14 PM
SSpdDmon's Avatar
1st off - This board needs spell check bad!
"rephrase"
2nd, the owner of that car said what he did right on his webpage. He sanded and painted the intake and polished the tb and MAF. I'm assuming with the metal parts, he started with maybe 800 grit sand paper and worked his way up to 2000??? Then, probably used some sort of rubbing compound and finished it off with a polish. Search around on google or yahoo. I'm sure you'll find something on polishing up metal surfaces.
Old Jun 23, 2005 | 12:27 PM
poxz's Avatar
Rephrase....I knew that..
Thank you thats exactly what i needed.
Old Jun 26, 2005 | 10:29 AM
ChicagoTransAm's Avatar
"rephrase"
Actually you will want to start with something around 400ish....you need to remove quite a bit of casting imperfections....I'm in the process of doing the same thing right now.
Old Jun 27, 2005 | 03:29 PM
SSpdDmon's Avatar
800 was a total guess.
Old Jun 28, 2005 | 02:57 PM
Bayer-Z28's Avatar
Leave myy drunk posts and bad spelling alone!!!
"Flitz It!" 1500 grit paper or Emery Cloth, I'd immagine. Never-dull works wonders too!
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
