Please read this... Need some suggestions...
Old Jun 16, 2002 | 09:13 PM
Michael Ozorowsky's Avatar
Post Please read this... Need some suggestions...
Hey guys. My mods are in my sig. What I am after is a Street Legal mid to low 10 second car. I am currently in the works of getting FLP headers, and a 12 bolt rear-end. What else would you guys recommend? I was thinking of like an 8# procharger, with a nice heads/cam package. What EXACTLY would I need? I am looking for exact numbers, lift duration, etc. I know you cannot TRULY tell whether I will run 10's, but I want to at least be in the ballpark. What Stall/Torque Converter do you recommend? I know this will cost a bit of money, and I am looking to spend as little as possible, however I am willing to spend $10,000 if it takes it. Am I going the wrong approach? Should I look into a 383 stroker? What do you guys suggest? Should I not look into a supercharger at all? Please list what I should get after my 12 bolt rearend. I am working on the suspension currently, so don't worry on that too much. Thanks, guys. I know there are a LOT of you guys in the 10's, so please tell me which route you personally suggest. Thanks.
--Michael
'01 Camaro SS A4
Mods Include:
Superior 3.73 Gears, Jet Chip Racing Chip, K&N Air Filter, Free Ram Air Cut-out, Granatelli MAF, Whisper Induction Lid, Corsa Cat-back Exhaust, Jet PCM Controller--Calibrates for my gears, Auburn Carrier, Hypertech 160 Degree Thermostat, SLP Strut Tower Brace, Sub Frame Connectors, Throttle Body Bypass, Powerslot Slotted Rotors, Hawk Performance Brake Pads.
Best 1/4: 13.192 @ 106.38MPH w/2.086 60' on GoodYear Eagle F1 tires.
Recent 1/4 run on 4/10/02: 13.502 with a 2.367 60' on 275x40ZR17 Dunlop SP sports, without the 160 thermostat, STB, SFC, or TB Bypass--With Some DR's, maybe run a 12.8, or 12.7? Fingers crossed. Headers coming soon.
See "Cammie" at http://members.cardomain.com/ozorowsky
Old Jun 17, 2002 | 10:44 AM
Serial Thriller's Avatar
Post
Well, there are a lot of ways to get there. But remember, it's not hp alone, traction/suspension is a big factor. I've seen folks with very few mods hook-up their way into the 11s/10s, and others with sick hp slip and slide their way to "only" 10s.
But about hp, you can stroke, spray, or supercharge (or turbo) your way into the 10s, but either way I'd plan on doing heads/cam to match whatever setup you go with. You'll also want to beef up your tranny and get a convertor that corresponds with your engine mods.
Have you checked around at LS1.com or the LS1 Tech section here? You'll find more specific answers for your '01 there.
More fun than the law allows!
Old Jun 17, 2002 | 08:03 PM
Post
I am kind of a newbie to racing all together. I have SOOOO MUCH to learn. I can't figure out which way is the best for my motor, and am looking for the SPECIFIC setup which should get me there. And what do you mean by beef up my tranny? Get another one? Thanks.
--Michael
'01 Camaro SS A4
Mods Include:
Old Jun 17, 2002 | 09:03 PM
racer1's Avatar
Post
10s shouldnt be too hard with a ls1 i would stay with your stock rearend as long as possible i run 10s on the stocker autos are generally easier i would stay away from turbos & s/c & would go with a proven heads/cam package & small nitrous & every suspension piece you can get thats the cheapest way & thats a 10 sec package
racer1
lpe heads,intake,mac headers,nos,random torque arm,eibach drag kit,3.73s,slp,callaway honker,sfc,msd,c/e rear shocks,afpr,march pullies
Old Jun 17, 2002 | 10:02 PM
Post
I am not into nitrous. Heads and Cams alone won't get me here right? Well at least street legal ones.
--Michael
'01 Camaro SS A4
Mods Include:
Old Jun 18, 2002 | 01:20 AM
AdioSS's Avatar
West South Central Moderator
Post
Here is what a local guy has:
a relatively small cam (I can't recall the specs, but it is very close to the LS6 cam)
locally ported heads
stock LS6 intake
3.73s in a 12-bolt
SLP long tubes
2800 Vigilante converter
lots of suspension work
275/40ZR17 Nitto DRs on stock rims with the same size up front
Oh yeah, a TNT 100 shot
He's run a best of 10.82 @ ~124mph.
There are getting to be more and more LS1 cams out there. Go with a relatively big one with well ported heads, put a big Yank or Vigilante converter in (at least 3500 stall), 3.73s with an auto or 4.10s with a stick in a strong rear end, put some sticky tires on it and GO! That'll put you deep in the 12s EASY. You can spray it and do some suspension work and you'll get at least low 11s, probably 10s with good weather.
Cheston P - IM_A_0@yahoo.com AIM:Impalaitis
96 BBB Impala SS "ADIOSS"
91 white Caprice 'n0n 9c1' w/L03
GM_TBI listserv
GMForums.com
ImpalaSSForum.com
Old Jun 19, 2002 | 07:18 PM
kmook's Avatar
Advanced Tech Moderator
Post
Michael, you may want to check out the LS1 Tech section. You should get a few more answers there so i'll get this over there...
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Asperated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Jesel Shaft Mount Rockers,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
ad356
Apr 22, 2015 08:35 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
JasonD
Jul 15, 2002 02:17 PM
