please help with spark plug issue if you can?
Old Apr 28, 2004 | 09:33 PM
Z28Venom's Avatar
Car Setup
2000 M6
33330 Miles
LS1 5.7 Ported Heads
TR230/224 111LSA Cam
SLP LID
It keeps fouling the #5 Plug... I know that it isn't OIL... It's carbon fouling.
Plug looks exactly like this: Carbon Fouling
Not like this: OIL Fouling
I've switch the 3 and 5 coil packs and the problem stayed with the 5 cylinder. I also switched the plug wires.
Is a faulty injector the only other thing that it could be?
Thanks for any of your help..
Old Apr 28, 2004 | 09:44 PM
mullettour's Avatar
Sounds like an injector to me.
Old Apr 29, 2004 | 04:10 AM
AL SS590 M6's Avatar
Moderator
Hey swap #5 injector with it's neighbor. They are easy to swap.
Old Apr 29, 2004 | 10:14 AM
Z28Venom's Avatar
I had the compression test done last night. The 1-3-5-7 cylinders all ranged from 145-150PSI on the tester that we used...
The exact numbers were:
#1-150 PSI
#3-150 PSI
#5-145 PSI
#7-145 PSI
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Iamherefornow
Jan 26, 2015 04:57 PM
