Please Help Me My Car Isn't fast enough!!!
Old Dec 22, 2006 | 01:47 PM
Playboy's Avatar
I want to put an LS2 crate motor in my 1995 Z28. I need help finding the K-member and any other mounting conversions I will need to have this monster installed. I know it will cost apretty penny but I'm gonna take my time and have it done right. Can any one help me with what I need or with a shop in the Chicago area that I can have it done at?
Old Dec 22, 2006 | 02:48 PM
93redBirdMan's Avatar
I'd save your money and do heads/cam on your LT1 and be a lot faster than the LS2... (stock LS2)
Old Dec 22, 2006 | 03:08 PM
2000GTP's Avatar
I'm sure Speed-Inc in Schaumburg can do that for you, but it will cost a pretty penny. As mentioned above, a heads/cam swap on your current LT1 would be the cheaper option, but an LS2 would definitely be cooler in my opinion.
Old Dec 22, 2006 | 10:57 PM
Playboy's Avatar
But the problem is that my LT1 has 190K miles on it and it really isn't built to handle 400+ hp continuously as a daily driver so I've been advised by people who have blown up enough engines that the most reliable way to go is an LT1 or better. Money doesn't really matter because like I said I'm taking my time.
I have already put high flow heads on it allready and it is great but like any real horseower freak its not quite enough for me. 95z28 340hp ALL OF IT GETS TO THA GROUND!!!!!!!!!!!
Old Dec 23, 2006 | 12:27 AM
VinceTrifecta's Avatar
If money is no object, why not do an LS7 then? ;-) It's made to run 500HP all day long.
Old Dec 23, 2006 | 09:24 AM
AL SS590 M6's Avatar
Moderator
For the K-member just swap your LT1 K for an LS1 K. You could get a tubular or buy someones (like mine) stock take out.
Old Dec 23, 2006 | 09:40 AM
Greed4Speed's Avatar
Even after you do all these things, it still won't be fast enough. You'll always want more.
Old Dec 23, 2006 | 10:10 AM
skifast87's Avatar
so very ture
Old Dec 23, 2006 | 12:14 PM
angel71rs's Avatar
In your place, I'd buy a good used LT1 block and throw a forged 383 kit in it. R & R over a weekend yourself. Much easier to do than going with an LSx and all the needed changes. Make more power, added insurance of forged components. Only advantage the crate LS2 would have in stock form would be the cool factor.
Think about all the stuff you'd have to change... headers, intake, wiring, etc. It's going to be a garage queen for a long time, and I've seen a lot of guys do a lot of hair pulling over garage queens. Nickel and dime you to death, some even losing enthusiasm for the project and end up selling it cheap. 383 swap = running in days.
Old Dec 24, 2006 | 11:49 AM
danziger's Avatar
I concur. A nice 383 with good heads and a little shot on top should keep you happy. It will be less headaches and cost about the same.
Old Dec 24, 2006 | 02:54 PM
bbf501's Avatar
What kind of power??
I'm new to Comaro's and this board. Just curious on what is a reasonable power expectation for a 383 with good heads, cam, etc... Thanks in advance..
Old Dec 24, 2006 | 03:14 PM
2000GTP's Avatar
Did you swap in a cam as well? If you just did the heads then you can't expect to get huge numbers.
Old Dec 24, 2006 | 10:05 PM
byrons1502's Avatar
put a turbo or supercharger on it. don't be scared
Old Dec 26, 2006 | 03:24 PM
danziger's Avatar
Not to be the spelling-****, but it's Camaro, not "Comaro"...
I don't see why a well-built LTx-based 383 can't do 450rwhp if top quality parts are used. It will all come down to the budget on the heads...
Old Dec 26, 2006 | 03:26 PM
danziger's Avatar
Oh, and if you were talking LSx-based 383s, there are some well above 500rwhp, but most (like mine) are in the 460-490rwhp range. I didn't use anything exotic in my build and am very happy with it...
