THE PERFECT SOUND (vid inside)
Old Jun 1, 2006 | 11:43 PM
  #16
AL SS590 M6's Avatar
Moderator
Re: THE PERFECT SOUND (vid inside)
Originally Posted by Greed4Speed
There are many LS1's runnig low 11's with the stock rotating assembly. Do you think they're not spinning above 6k?
Me me me I have been shifting at over 6400 rpms drag racing regularly for 3 years now since I went Heads/Cam. Totally stock bottom end.
Old Jun 2, 2006 | 01:50 AM
  #17
RussStang's Avatar
Originally Posted by Taintedz28
I read as much as i can, but ok wow 6500 is plenty into the redline for me, and 6900 is only 100rpm off from what the motor will take max
Dude, I have no idea what you are talking about. Change out the stock pushrods and valvesprings for better ones, and you can rev a stock bottom end LS1 to 6500 rpm as much as your heart desires. Swap out the rod bolts, and there is no reason the motor can't see about 7k (although a better oil pump and timing chain might be a good idea). Some of the guys with 01 and up LS1s that have the better factory rod bolts can take their car to 7k on the stock rod bolts no problem.
Just out of curiousity, what RPM does the T-Rex cam build power to? I would think somewhere over 7k with the cam's specs.
Old Jun 2, 2006 | 06:45 AM
  #18
teke184's Avatar
"i wouldnt want to rev a stock motor past 6k without some serious upgrade to take that type of beating"
you DO realize that the stock rev limiter is almost 6200 in the ls1 ...right?
6500 is no big deal.... over that...well i think you're buying your time till a failure of some kind.
Old Jun 2, 2006 | 02:24 PM
  #19
blackrat's Avatar
ok, so say with with a decent sized cam, staying NC emissions legal, and upgrade rods, bolts springs, lifters, how high couldi SAFELY spin it?
if Youre only going with a "decent" sized cam, then you dont have anything to worry about, as long as you get the springs to match it, which they should come with anyway. its only when you go with a big cam that you should start to worry. again though, we're talking ls1 here. dont know what an lt1 is capable of.
blac94Z
19
May 13, 2015 04:50 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
