Patriot heads
Old Mar 22, 2005 | 10:37 PM
emd820's Avatar
Patriot heads
Are patriot heads that bad? thanks
Old Mar 22, 2005 | 11:23 PM
Beast96Z's Avatar
Re: Patriot heads
Yep. There are to many other heads out there right now for the same price that are much better. There is a GP on another vendors heads over on LS1tech right now. Look in the Group purchase section. Ther about the best heads you can get for $1500.
Old Mar 24, 2005 | 06:36 PM
Antz97ZNJ's Avatar
Re: Patriot heads
Some ls1 guys had problems w/ them when they first came out...same w/ the stang guys...they have since been revised and are now a quality piece...
Old Mar 25, 2005 | 06:52 PM
Beast96Z's Avatar
Re: Patriot heads
They may not break on you, but they will deffinatlly not perform up to par with other heads in the same price range. There was a good thread on LS-1 tech were the Patriots were compared with FFHP stage 1 heads, and the performance was BAD. This was even a set of heads that Patriot sent to be tested against the FFHP's in a test that they called for. If quality means they won't break, then yea, there quality, but as for performance, they won't flow and or make the hp that is claimed.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
