Pacesetter LT & Texas Speed catted Y pipe
Old Apr 3, 2008 | 06:27 PM
  #16
SFB767's Avatar
Originally Posted by knote
just got home from work, do you still have the car? Did you do the install yourself? My y pipe is in several pieces and has clamps. Do you know other people that had problems with the TSP y? I went with their's over the pacesetter because it had the cats and figured an ory would be too loud with my loudmouth catback. Did it bang all the time or just under certain conditions? It will be the 18th before my car goes in to have this done, any install advice for the y I purchased?
Yeah, I still have the car. The install was done by a GM Master Tech. and it took almost all day. My friend has a TSP ORY on his car before I bought mine and his bangs too. Mine banged under load. From a dead stop, unless you launched the car like an old lady, it would bang, scrape and grind like crazy. You'll feel a difference, definitely, I just wish I could muster better than the time in my sig. with my setup, with a 2.0-2.1 consistently. Must be the auto.
Old Apr 3, 2008 | 09:34 PM
  #17
knote's Avatar
I want to beat my friends 07 Mustang GT, he's done nothing but exterior mods and he is waiting on a side exit exaust from Cervini. His is a manual car too and he talks big trash on my car-I want my 10 yr old Camaro to get him before he does a single turbo. He is also my boss and has a lot more $$$ for mods than I do. Other than NOS, what would be the best next bolt on for a budget? Intake? Pulley's? SLP MAF? Drag radials? I told him I could take him now but he doesn't think I could beat him.
Old Apr 12, 2008 | 08:18 PM
  #18
knote's Avatar
install complete!
I am new to posting so sorry this isn't in the exaust section were it belongs. My 98 has the coated Pacesetters and the TSP catted Y pipe hooked up to a SLP lm1 catback. It isn't any louder at idle than it used to be but it is LOUD at WOT. The y is hitting the floor like you said it would but not real bad...might rap something around it or have it adjusted to see if I can get rid of the bang. It definitely gave a SOP difference and I am looking forward to seeing what kind of et I can get when I can go to the track..Tires are helpless if I try to leave at a 2000 but bogs under 1500...guess I need to practice or get some DR's and hope I don't break a rear end.
Old Apr 12, 2008 | 10:58 PM
  #19
MarylandSpeed's Avatar
I would only run the LMII with headers...that is one of the reasons SLP came out with it in the first place.
Old Apr 12, 2008 | 11:49 PM
  #20
Zitty'sZ's Avatar
The y-pipe is probably hitting the floorboard because your motor mounts are worn and or broken , which is allowing the engine to tourqe towards the passenger side causing the exhaust to hit the bottom of the car . A set of prothane motor mounts will solve that problem as they keep the engine rock solid .
alphaauto
Jan 23, 2015 07:42 AM
Jan 5, 2015 07:14 PM
Brad 97z
Aug 10, 2002 09:58 AM
