p0137
Old Apr 28, 2008 | 07:57 PM
TJ Chapman's Avatar
p0137
"P0137 O2 signal low bank 1 sensor 2" is that the passenger side manifold o2 sensor?
Old Apr 29, 2008 | 06:12 AM
AL SS590 M6's Avatar
Moderator
Bank 1 is the driverside and sensor 2 is the after cat sensor and it has no effect on performance.
Old Apr 29, 2008 | 09:12 AM
TJ Chapman's Avatar
no but it doesset off the SES light and i do have to go pass emissions soon. could that be a problem with the cat?
Old Apr 29, 2008 | 12:30 PM
2001NBMZ28's Avatar
Probably not the cat, I'd take a look at www.gearchatter.com/viewtopic8899.php
Old Apr 29, 2008 | 10:57 PM
TJ Chapman's Avatar
well any last heads up to prevent wasting $150 on an O2 sensor or is that probably right?
Old Apr 30, 2008 | 07:07 AM
Moderator
Yep, go out and crawl under the car, swap the after cat O2 sensors, reset the PCM, and see if the code comes back.
If it does come back as bank 2 sensor 2 then you'll know for sure that it's a bad sensor.
joshdoty23
Sep 21, 2012 02:21 PM
taviz
May 1, 2012 05:20 AM
Ryatt-SS
Oct 29, 2009 07:40 AM
4gltoness
May 29, 2009 09:58 PM
Drew '97 Z28
Dec 20, 2005 04:36 PM
