Okay Ls1 Guru's Come Inside
Old May 31, 2005 | 03:03 PM
CHELOZ28's Avatar
I currently have a Lt1 with 100k, my friend with a 02Ws6 just purchased a new Ls6 and will be giving me his old LS1 motor only 60k on it. I was wondering will this fit in my 1995 z28, what else would I need to purchase to make this work, and how expensive will this swap get?
Old May 31, 2005 | 03:12 PM
CHELOZ28's Avatar
Re: Okay Ls1 Guru's Come Inside
anyone help??
Old May 31, 2005 | 04:47 PM
Antz97ZNJ's Avatar
For one I believe you'll need a new hood and wireing system
Old May 31, 2005 | 06:27 PM
Kataklysm's Avatar
Yes it will work but its not gonna be just a put it in a bolt it up thing. You can modify the induction so you won't need a new hood (I THINK) I know the tranny bellhousings are different so you will need an LS1 trans or bellhousing. You deifnitly need the PCM and wiring harness as well. I'm sure theres probably more too.
Old May 31, 2005 | 06:53 PM
CustomSSI's Avatar
You'll also need a new crossmember......
Josh
Old May 31, 2005 | 11:37 PM
CHELOZ28's Avatar
Cool Re: Okay Ls1 Guru's Come Inside
Do you guys think this will be worth the hassle? Also I'm kind of debating if should just sell the Ls1 and with that money rebuild my lt1 get some AFR heads and a good street cam. Too many possibilities, how much would a used LS1 go for?......
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
