Okay, dont bite my balls off, but, seriously, biggest cam for stock stall
#18
you can use as big a cam on a stock converter as you wish. I ran a 236/242 on a 112 lsa with stock gears and converter. I had to commute over 50 miles a day (work and back) in the city, freeway, and traffic and through rush hour in -30 degree weather (makes startup a little tricky).
#19
get a mid 220s cam with steep lobes and high lift. You'll have a mean idle that wont be too harsh, cam surge should be easy to program out, you'll have enough off the line punch to spin the tires and you will pull well past 6000 rpms.
You should be able to hit 180+mph, something a high stall or gears will prevent you from doing
A high stall in a 4l60e has NO effect on top end because it is a lock up converter. And yes it will lock up at WOT.
#20
Again, GT2-3.
#22
It can be, just like the Z06 cam can be but it wasn't designed for it. It was designed to run under stock parameters while making more power than the Z06 grind.
When you tighten up the LSA you increase overlap and will lose some of the smooth idle. You may like the stealth cams from MTI.
#23
Stock one doesnt lock at WOT, so the high stall will actually be MORE efficient.
Brandon Wittmer
12-20-2014 09:51 PM
