oil pressure gauge tubing
Old May 11, 2011 | 04:59 PM
classics69's Avatar
I have a 98 camaro ls1 and i want to mount a auto meter oil pressure gauge in the port above the oil filter, does anyone have any pictures off the best way to route the line, and if the copper line will be okay, because it will be only a inch or two from the cat and exhaust, i don't know how it is with heat? thanks
Old May 16, 2011 | 09:58 AM
Marc 85Z28's Avatar
Re: oil pressure gauge tubing
Copper line? You're not using a mechanical gauge are you?
You should be using the electrical setup. Remove the plate, drill and tap for the sending unit, then connect the wire. Really simple. It should clear just about any header - it clears my Hookers.
Old May 17, 2011 | 02:22 PM
classics69's Avatar
I have a mechanical one, but i was worried about routing the copper tubing, so i ordered an electric gauge, does it matter how close the electrical sender is to the exhaust, will the heat effect it? thanks
Old May 17, 2011 | 03:02 PM
Marc 85Z28's Avatar
The heat should not affect the sending unit. My Hooker headers are very close to the unit, but almost 7 years later it still works.
Old May 17, 2011 | 03:06 PM
classics69's Avatar
Okay well mine will be within an inch of the cat, it has factory exhaust on it, have you had any leaks from the sender? Did you drill that port above the oil filter and run a tap in it? I read somewhere to drill a 5/16 hole and then use a 1/8 npt tap, I am not sure if that is right or not.
Old May 18, 2011 | 10:25 AM
Marc 85Z28's Avatar
No leaks. That little plate easily unbolts from the oil pan which makes drilling an tapping much easier. I don't remember what size drill bit and tap is required.
Old May 18, 2011 | 01:59 PM
classics69's Avatar
Okay thanks, i did get some of that heat wrap for hoses and wires, i will wrap the sending unit up with that and try to route the wire up around the exhaust some where.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jul 4, 2005 05:00 PM
