oil missing?
Old May 2, 2007 | 09:37 PM
touch109's Avatar
Exclamation oil missing?
I just checked my oil and noticed i was missing about 2 qts of oil. this is the second time this has happened .. it happened last time i changed the oil is was half empty.. i wanted to know what could it be.. there no signs of oil leak, none on the garage or dirve way.. checked under the car nothing there.. the car has 59000 miles on it i always used mobil 1 5-30.. there is a ticking noise when i warm up it up.. i just thought it was the noise all camaro make at start up.. if anyone knows let me know..
Old May 3, 2007 | 08:12 AM
AL SS590 M6's Avatar
Moderator
Change your PCV valve.
Old May 3, 2007 | 08:55 AM
Kraest's Avatar
Retired
Many LS1s consume around a quart of oil between oil changes. If changing your PCV valve doesn't work, then just accept that fact.
Old May 3, 2007 | 03:04 PM
2001NBMZ28's Avatar
At about 2 quarts low the "low oil" light should illluminate.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
KYWes
Apr 15, 2015 05:48 AM
Cam's maro
Mar 24, 2015 08:09 PM
captcorvette
Mar 7, 2015 12:37 PM
